2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: dataAccess V4 Ca client propertyId questions
To: Kay-Uwe Kasemir <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Tue, 28 Jun 2005 15:38:39 +0200
Kay-Uwe Kasemir wrote:
Hi:
How does it get started, i.e. how does it know how to find properties associated with the pvname?
I forgot the circumstances, but one point at the SLAC meeting
was that we might have to abandon the idea of "fred" == "fred.VAL".
If you want the default value, you'll have to use "fred.value"
in the new command-line 'caget' or the 'probe' GUI.
If you use "fred", you will get _all_ properties of fred.
It'll be consistent for the whole hierarchy:
In case "fred.limits" is a structure, "fred.limits" will get
all structure elements. "fred.limits.display.high" might drill
down to a structure element.
Yes. But maybe not quite exactly.
Have a look at the wiki page where Andrew describes the idea of Views. For me, that's a really really promising way to go. Grouping things in a reasonable way, providing flat as well as deep structures, use of parameters, there's a lot of good stuff in there. Gains attraction while you think about it.
http://www.aps.anl.gov/epics/wiki/index.php/V4_Standard_Properties_and_Events#Views
Ralph
dataAccess V4 Ca client propertyId questions Marty Kraimer
Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
Prev: Re: V4 design issue: Should primitive data types have well defined precisions? Ralph Lange
Next: Re: dataAccess V4 Ca client propertyId questions Ralph Lange
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: views Andrew Johnson
Next: connections, beacons, ...: Only directory and TCP? Kay-Uwe Kasemir
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
