Subject: |
Re: dataAccess V4 Ca client propertyId questions |
Andrew Johnson <[email protected]> |
To: |
EPICS Core Talk <[email protected]> |
Date: |
Mon, 27 Jun 2005 16:23:15 -0500 |
Kay-Uwe Kasemir wrote:
I forgot the circumstances, but one point at the SLAC meeting
was that we might have to abandon the idea of "fred" == "fred.VAL".
True, and from that I developed the idea of supporting named views of
the record. The dot now separates the record name from the view name,
and some views will take simple parameters in parentheses.
If you want the default value, you'll have to use "fred.value"
in the new command-line 'caget' or the 'probe' GUI.
If you use "fred", you will get _all_ properties of fred.
Not quite. There should still be a default view for each record type,
so you can still say "fred" and you'll get something analogous to the V3
"fred.VAL" default, but in V4 the record type has more control over what
you will actually get back, and you will probably *not* get _all_ the
properties, just the ones appropriate to the record's main value.
It'll be consistent for the whole hierarchy:
In case "fred.limits" is a structure, "fred.limits" will get
all structure elements. "fred.limits.display.high" might drill
down to a structure element.
Ammend that slightly: your "fred.limits" becomes "fred.field(limits)" to
view the complete "limits" field structure, although if the record type
defines a "limits" view then "fred.limits" would be correct. To drill
down though you would have to use something like
"fred.field(limits.display.high)"
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
- views Kay-Uwe Kasemir
- dataAccess V4 Ca client propertyId questions Marty Kraimer
- Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
Re: More flexible record scanning Benjamin Franksen
<2005>
<2005>
