Subject: |
connections, beacons, ...: Only directory and TCP? |
Kay-Uwe Kasemir <[email protected]> |
To: |
EPICS Core Talk <[email protected]> |
Date: |
Mon, 27 Jun 2005 14:29:33 -0400 |
Hi:
This is a level down from the API to the actual implementation,
but I think that we should be open to review how CA handles
connections:
Broadcasts to locate PVs,
beacons to monitor established connections and to
spot new servers.
At the SNS, there are ongoing problems with connections not
happening or taking a long time.
My point is that every single issue can be fixed,
but I think we're trying to be overly sophisticated
without real benefit.
Yes, it works great in most cases, by when it doesn't,
it's very hard to figure out what's wrong.
How about using a directory and then only TCP connections
with idle-messages to monitor the connection state?
- need to run a directory server
- directory server is bottleneck
+ a directory based on an existing protocol like LDAP
can be populated and queried with several methods.
You know what's in the directory, you get reproduceable answers.
+ there can be redundant LDAP directory servers
+ one can use ssh tunnels for the TCP connections
+ better debug messages are possible: "cannot access directory
LDAP:123.0.0.1",
"cannot access 'fred' on CAS 123.0.0.2:5001 where directory
LDAP:123.0.0.1 reported it".
Kay
Begin forwarded message:
Date: June 27, 2005 13:11:00 EDT
To: "Ernest L. Williams Jr." <[email protected]>
Subject: Re: How to inspect the nameserver's hash table?
Hi Ernest,
I am in the process of adding code to the nameserver to handle
CA gateways differently than regular iocs. Each pv from a CA
gateway has to be monitored separately because each pv can
connect/disconnect independently. I recently created a new
monitorAll variable to force the nameserver to monitor all
learned pvs (in main.cc around line 180) but this variable is
temporary until I am able to add some input data to identify
gateways. We do not use the learn mode except for gateways
so I have hard coded monitorAll to true (1). In your case
when you want to learn about all iocs you will need to set
monitorAll to false (0) and recompile. Sorry about this but
code changes for the separate handling of gateways is not
fully implemented yet.
Janet
- Re: connections, beacons, ...: Only directory and TCP? Matthias Clausen
Re: V4 design issue: Should primitive data types have well defined precisions? Marty Kraimer
Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
<2005>
Re: dataAccess V4 Ca client propertyId questions Ralph Lange
<2005>
