I'm attaching a tar that contains an excerpt of the code that I was
using to do my dataAccess performance tests for the ICALEPCS 2001 paper.
Note that this is code from 2001, so it is for the April 2001 version of
dataAccess and has to be adapted for the current version to compile and
work.
Is this the kind of example code that you are looking for?
This of course is pure dataAccess - I don't have anything working for
the new CA client interface - this was not existing in 2001.
Want more? Well, the complete test code (with all the other classes for
other type data, including arrays, strings, sub-containers) has been in
the obviously named "testApp" directory of the dataAccess tree in the
APS CVS repository for more than four years now. How stupid of me! I was
always assuming that you know this code, so maybe that explains part of
my not understanding your demand for example code at all. I'm sorry.
The dataAccess tree in CVS also contains a thin library layer to put a
dataAccess interface to the existing V3 Database ("daApp/dadb"). This
had been tested except for the array type, which was still buggy when I
left the APS end of April 2001. Same note about working with 2001
version dataAccess only applies to that library.
If you want me to tar up the complete APS repository to send it to you
by mail, just let me know ... ;-)
Ralph
Eric Norum wrote:
On Jun 22, 2005, at 8:44 AM, Ralph Lange wrote:
You are expecting a usage example for interfaces that have not been
fully designed yet while Bob is questioning the underlying principles?
Abslurd.
Perhaps, but if the outcome of this design process is a system which
is so complicated that no ordinary developer can understand it then no
ordinary developers will use it. Perhaps the 'outer level' API is
clear to you, but at the moment it's not clear to me. That may say
more about me than it says about the API, though.....
- Re: hello world examples Ralph Lange
- Re: hello world examples Marty Kraimer
- RE: Puts Dalesio, Leo `Bob`
- hello world examples Marty Kraimer
Re: V4 design issue: Should primitive data types have well defined precisions? Ralph Lange
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
