Benjamin Franksen wrote:
On Thursday 16 June 2005 12:55, Benjamin Franksen wrote:
On Wednesday 15 June 2005 23:12, Andrew Johnson wrote:
To step back a little: I don't understand why your states have
parameters, and what you could do with them - presumably I can't
put a CA monitor on a member of a tagged union (what happens to the
monitor when the state changes and the member no longer exists?).
It must disconnect, indicating that the value in question no longer
exists. Note that a similar question must be answered for the case of
adding/removing views. Here, too, the client will need to receive
notification that a certain value is no longer available. We could
make this a dedicated event type so that clients can react in a
generic way to such conditions.
Let me state this more precisely:
The very idea of a tagged union implies that independent read or write
access to properties subordinate to a certain tag hardly makes sense. I
cannot change, nor query, the scanRate of a record, as long as I am not
certain that the tag is 'Periodic'. However, subscribing to merely a
certain subordinate property might reduce system load.
The problem is that changing the tag independently brings the other
subordinate properties to an undefined state and this is something we
can't handle because we don't have a representation for "no value
here". Thus, at least write access must provide all values every time
(i.e. tag + add. properties), while reading and subscribing to either
tag only or other properties can be allowed but must fail in case of
unavailability.
Hm. I don't see any problem with my original idea to have the write
traversal for a tagged union (exactly like the read traversal) first
provide the tag and then only the properties that are valid for the new
tag value. Valid write operations would succeed, invalid operations
would fail, no meaningless properties being provided in the process.
Ralph
- Re: V4 Data Types: Request for tagged unions Benjamin Franksen
- RE: V4 Data Types: Request for tagged unions Jeff Hill
Re: meeting in July / ca interface specification Doug Murray
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
