2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: meeting in July / ca interface specification
To: Matthias Clausen <[email protected]>
Cc: [email protected]
Date: Tue, 14 Jun 2005 12:02:41 -0400
Hi:
On Jun 14, 2005, at 11:41, Matthias Clausen wrote:
It comes to my mind that the interface for channel access V4 should be also discussed and defined by those people writing the high level (machine)physics applications. They will probably have the highest demand for new features.
I completely agree with a high level approach.
I'm spending many evenings and weekends in the control room
these days and my most important tool is Matlab w/ channel access.
In there, it helps to have an API ala
    cavity_amp = caget('DTL_LLRF03:cav_amp')
and then cavity_amp is a double[1024] or int[16k],
far removed from the low-level API of assembling
a property catalog, connecting, ...
Will Kay and Doug coordinate this issue? Otherwise I'll be glad to help.
I did some LDAP-based tests for a directory server which is on the wiki,
I'm also checking ZeroC Ice as suggested by Andy Foster for performance
and ideas as a possible communication mechanism.
Overall, however, I clearly don't have the time that I'd like to have for V4 work,
so I'd not only be a bad coordinator but actually wonder if
I should quit before the rest of the group counts on my work
and then we all fail because I can't deliver.
-Kay
meeting in July / ca interface specification Matthias Clausen
Prev: RE: meeting in July / ca interface specification Dalesio, Leo `Bob`
Next: Fundamental Types document Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: meeting in July / ca interface specification Matthias Clausen
Next: RE: meeting in July / ca interface specification Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
