g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Subject: Base V4 Database: Alarms for analog type records
To: Marty Kraimer <mrk@aps.anl.gov>
Cc: Bob Dalesio <bdalesio1@comcast.net>, Ned Arnold <nda@aps.anl.gov>, Andrew Johnson <anj@aps.anl.gov>, Eric Norum <norume@aps.anl.gov>, Janet Anderson <jba@aps.anl.gov>, Jeff Hill <johill@lanl.gov>, Matej Sekoranja <matej.sekoranja@ijs.si>, Ken Evans <evans@aps.anl.gov>, Benjamin Franksen <Benjamin.Franksen@bessy.de>
Date: Thu, 03 Mar 2005 15:00:50 +0100
Hi all,
I find that for all analog type records, the fixed number of alarm limits and severities is a constraint that should be removed.
I would rather have the analog alarms organized like a breakpoint table, consisting of a series of ranges with a severity (and a status?) for each. The default would be no table, which is the complete range being "NO_ALARM".
Maybe some breakpoint table code and parsing can be re-used.
The hard part is probably that CA and the clients on the other end would have to reflect this structure, which is not a fixed-number set of attributes anymore. Rather an array of (value, value, (status?), severity) structures.
The other open question is: Changing alarm limits is not just setting a field anymore, it means reloading a breakpoint table. Is that acceptable? Must the alarm limits be writable through CA?
What do you think?
Ralph
Ralph Lange               Ralph.Lange@bessy.de     Tel: +49 30 6392-2117
BESSY Controls Group      www.bessy.de             Fax:      ...   -4859
Prev: Re: EPICS base V4: iocCore database Benjamin Franksen
Next: Announcing the core-talk mailing list Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: memory management Benjamin Franksen
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
