On Thursday 24 February 2005 00:52, Andrew Johnson wrote:
> Proposal for V4:
> Change the way in which records are executed, allowing the database
> designer to select which threads perform processing of particular
> sets of records.
General comment: very good idea.
> In V3 we create a thread for each scan period, plus a number of other
> threads for callbacks etc. so the thread that a record processes in
> is vaguely related to its SCAN and PRIO fields. I propose changing
> menuScan so it only contains "Passive", "Event", "I/O Interrupt" and
> "Periodic". We add another field which is a double called scanPeriod
> which can be set to any period in seconds (this two-field approach is
> analagous to "Event" and the old EVNT field).
The data type of the new scan specification is quite naturally expressed
as an algebraic data type (=tagged union). In Haskell I would write
data Scan = Passive | Event Int | Interrupt | Periodic Double
In dbd syntax this could look like:
union(scanSpec) {
choice(scanPassive,"Passive")
choice(scanEvent,"Event") {
field(event,octet)
choice(scanInterrupt,"Interrupt",)
choice(scanPeriodic,"Periodic") {
field(rate,float)
(I took the freedom to allow leaving out an empty pair of braces "{}".
This makes the union notation compatible with the one for menus, which
are a special case of unions where all choices are tags only without
data.)
One more comment on event scanning. Currently events are specified by a
number between 0 and 255. This has many obvious disadvantages. I think
for V4 we should consider supporting event identification by name,
rather than number. The above would then become
union(scanSpec) {
field(event,string)
Ben
- EPICS base V4 Marty Kraimer
- Re: EPICS base V4 Andrew Johnson
memory management Jeff Hill
<2005>
Re: EPICS base V4 Ralph Lange
<2005>
