Some comments regarding the signed/unsigned conversion issue:
On Wednesday 23 February 2005 04:29, Jeff Hill wrote:
> > From: Marty Kraimer [mailto:[email protected]]
> > >Jeff Hill wrote:
> > >o Data access supports safe conversion between all of the
> > >primitive types available in C. If the source is out of range
> > for
> > >the destination the operation is not performed and an error is
> > >returned to the user. This has already been implemented.
> > Is this what we want?
> > Let me give an example
> > An IOC has a field that is an unsigned 32 bit integer.
> > A java application asks for the fields as a signed 32 bit
> > integer. The java application only uses the field as a
> > bit mask.
> > Should CA return an error if the value happens to have the high
> > order
> > bit = 1?
> > I say no.
> I say yes. No doubts from my perspective. How would the IOC know
> what the client is using the data for? This isn't close enough is
> good enough environment. We are coding a control system. We don't
> want intermittent failures that occur only when the data has
> certain magnitudes.
> If the bit field is an unsigned number and higher order bits are
> set then this would be a very high magnitude unsigned number. If
> this exceeds the magnitude of the signed type in the Java client,
> and if there is even the slightest possibility that any Java
> client might use the result as a signed number, and not as a bit
> field, then a disaster will eventually occur. A code that is
> sourcing out bit fields should be providing a way to specify the
> starting bit and the field length so that bit fields anywhere
> within a 32 bit unsigned number can be accessed, and the Java
> client upon encountering conversion problems could request the 32
> bit field as two 16 bit fields with complete safety and no loss
> of functionality.
Yes. Marty, in your proposal there is a data type to request in this
case: an array[4] of octets. Octet is explicitly specified to be used
in cases where the raw bit pattern is what is wanted, as opposed to an
integral /number/.
A predictable (immediate) exception is definitely better than eventual
failure when values go out of range.
Regarding the current use of unsigned types, there are three cases to
consider:
(a) A raw value that gets written to or read from hardware and that is
specified by the manufacturer to be an unsigned number.
(b) Any other integral number, that has a natural lower bound of zero.
(c) A bit field or enumeration.
I think the only real justification for using unsigned integral types is
case (a).
In almost all cases of (b), we can use a signed type (if strictly
necessary take the next larger variant), without losing anything
important.
As regards case (c), for enumerations we can and should create a menu of
choices. Bit fields should have either a dedicated basic type (bitfield
with a configurable number of elements) or else be just an array of
booleans, that gets automatically optimized into a bitfield.
The bottom line is that unsigned types should be used only in the very
few cases where they are essential to faithfully represent raw hardware
values.
Ben
- RE: EPICS base V4: iocCore database Jeff Hill
Re: EPICS base V4: iocCore database Marty Kraimer
<2005>
<2005>
