Hi Mark,
Ok, I found the problem - a bug in inet_addr(), which ftpXfer() calls
passing in the hostname string. This is the Tornado 2.2 version of the
code, which works:
inet_addr:
4e56 fff0 LINK .W A6,#0xfff0
48e7 3838 MOVEM .L D2-D4/A2-A4,-(A7)
226e 0008 MOVEA .L (0x8,A6),A1
47ee fff0 LEA (0xfff0,A6),A3
4a89 TST .L A1
6700 0150 BEQ error
4282 CLR .L D2
760a MOVEQ #10,D3
0c11 0030 CMPI .B '0',(A1)
6614 BNE not0
7608 MOVEQ #8,D3
5289 ADDQ .L #1,A1
0c11 0078 CMPI .B 'x',(A1)
6706 BEQ yesx
0c11 0058 CMPI .B 'X',(A1)
6604 BNE not0
yesx:
7610 MOVEQ #16,D3
5289 ADDQ .L #1,A1
not0:
1011 MOVE .B (A1),D0
It compares the first character with '0' and if it's not that defaults to
base 10 and attempts to convert the string into a number. If it is '0'
then it might be an octal number, but it also looks at the next character
in case it's an 'x' or 'X' meaning base 16.
This is the Tornado 2.0.2 version, which is broken:
inet_addr:
48e7 3038 MOVEM .L D2-D3/A2-A4,-(A7)
49ee fff0 LEA (0xfff0,A6),A4
4a89 TST .L A1
6700 014a BEQ error
4281 CLR .L D1
740a MOVEQ #10,D2
6604 BNE not0
7408 MOVEQ #8,D2
5249 ADDQ .W #1,A1
not0:
6706 BEQ yesx
6604 BNE notX
yesx:
7410 MOVEQ #16,D2
5249 ADDQ .W #1,A1
notX:
In this case, if the first character is not '0' it branches to the wrong
place and checks whether it's an 'x' or 'X'; thus one can give a hex inet
address as either 0x12345678 or just x12345678.
If you really wanted to fix this, you could take a hex editor and modify
the 0x6604 instruction which appears 0x1e bytes into the inet_addr
routine, replacing it with 0x6614 which fixes the branch to go to the
right place. However this is buried inside an object file which itself is
inside a library archive, and you probably don't want to go to all that
trouble.
A simpler solution would be not to use hostnames that start with an 'x',
or if you do just make sure that it includes a character which is not a
hex digit. Of course the IOC's idea of the boot host name doesn't have to
be the same as the rest of the world's either - you could tell the IOC
that it's booting from HOSTx17b3 and it'll be perfectly happy and
everything will work correctly.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night. That was really cool. - Caro
RE: Timestamp (drvTS) progress Jeff Hill
RE: Bug in MVME167 BSP? Mark Rivers
<2004>
Re: Timestamp (drvTS) progress Korhonen Timo
<2004>
