This is a thread that I thought was worth keeping...
Ralph
--- Begin Message ---
I have confirmed that the M$ compiler error is related to initializing a
file scope variable with the address of a variable exported from a DLL. I
fault isolated by initializing that same structure member with the address
of a local file scope variable.
It appears that iocshVarDef might be new functionality. One possibility
would be to change the interface and require that the application install
the address of four set and get functions as follows.
double myNumericGetFunction ( void );
void myNumericSetFunction ( double );
void myStringGetFunction ( char * pString, unsigned maxLength );
void myStringSetFunction ( const char * pString);
An advantage of this approach would be better support for application
specific functionality like range checking, state change action activities,
and mutex locking in the set/get functions. Note that on SMP systems mutex
locks are required around even atomic variable access when multiple threads
are involved in order to guarantee cache coherency.
Anyways, a possible option to consider.
PS: If you want to mess with many different data types you could have a type
code, a set/get interface for each of the data types, and have the
application install only the one set/get pair that is needed.
PPS: All of this starts to sound alot like data access by the way.
PPPS: Give me a call at 505 665 1831 if you would like to discuss this over
the phone.
Jeff
> -----Original Message-----
> From: Eric Norum [mailto:norume@aps.anl.gov]
> Sent: Tuesday, February 10, 2004 3:52 PM
> To: Jeff Hill
> Cc: 'mrk'
> Subject: Re: [Fwd: initializer is not a constant]
> Jeff Hill wrote:
> >>Hmm...shouldn't that cast be
> >>(void * const)
> >>i.e. a constant pointer to a void, not a pointer to a
> >>constant void......
> > I hadnt looked at your code so far. After a closer
> inspection I see this:
> > typedef struct iocshFuncDef {
> > const char *name;
> > int nargs;
> > const iocshArg * const *arg; <=== is being set, I believe
> > }iocshFuncDef;
> > Therefore the compiler wants a cast like this.
> > (const iocshArg * const *)
> > C (but not C++) compilers will probably also accept this.
> > (const void * const * )
> I'm not sure what you're getting at here. The problem is
> with an iocshVarDef
> initialization, not with an iocshFuncDef initialization, right?
> static struct iocshVarDef vardefs[] = {
> > {"asCaDebug", iocshArgInt,(void *)&asCaDebug},
> > {0,iocshArgInt,0}
> Eric Norum norume@aps.anl.gov
> Advanced Photon Source Phone: (630) 252-4793
> Argonne National Laboratory
--- End Message ---
a
DLL. I
address
So the solution is to move the variable declaration to the same source
file as the iocshVarDef and to specify the 'extern' in the source file
where it's now being declared, right?
install
This is similar to the old method where everything went through the IOC
shell -- and lots of people complained that it was too difficult to set
up access to variables.
activities,
mutex
threads
I remain skeptical about this requirement.
Eric Norum <norume@aps.anl.gov>
(630) 252-4793
--- End Message ---
> > Note that on SMP systems mutex locks are required around even
> > atomic variable access when multiple threads are involved in
Some interesting things can happen on SMP systems. For example the following
code can result in a failure in strlen() resulting from faulty assumptions
about sequencial ordering of accesses to atomic variable pBill which are not
guarded by a mutex.
extern struct bill {
char *p;
} * pBill;
void * p = 0;
if ( ! pBill ) {
lock
if ( ! pBill ) {
struct bill * p = malloc (sizeof(bill));
p->p = malloc(4);
p->p[0] = '\0';
pBill = p;
unlock
strlen ( pBill->p );
Changing the code as follows makes it safe.
char *p;
} * pBill;
void * p = 0;
lock
if ( ! pBill ) {
if ( ! pBill ) {
p->p = malloc(4);
p->p[0] = '\0';
pBill = p;
unlock
Admitedly, if you dont allow the iocsh to branch on the contents of a
variable then perhaps you will not run into these issues.
Jeff
> Sent: Tuesday, February 10, 2004 5:46 PM
> To: Jeff Hill
> Cc: Andrew Johnson; 'mrk'; 'Ralph Lange'
> initializing
> > a
> > DLL. I
> > address
> same source
> source file
> possibility
> > install
> through the IOC
> difficult to set
> application
> > activities,
--- End Message ---
following
assumptions
are not
guarded by a mutex.
My skepticism is rooted in my feeling that cache snooping takes care of
situations like this. Perhaps I'm overly optimistic.....
I'd really like to see a statement in a hardware manual that made it
clear once and for all whether or not a programmer needs to worry about
cache coherency at the level shown in your example.
(630) 252-4793
--- End Message ---
fyi
http://www.cs.umd.edu/~pugh/java/memoryModel/DoubleCheckedLocking.html
> Sent: Tuesday, February 10, 2004 7:02 PM
> To: Jeff Hill
> Cc: 'Andrew Johnson'; 'mrk'; 'Ralph Lange'
> > following
> > assumptions
> pBill which
> > are not
> > guarded by a mutex.
> takes care of
> worry about
> (630) 252-4793
--- End Message ---
On Feb 11, 2004, at 6:02 PM, Jeff Hill wrote:
fyi
Maybe....
but I interpret the message as a statement that Java needs a 'volatile'
keyword more than anything else.
(630) 252-4793
--- End Message ---
> http://www.cs.umd.edu/> ~pugh/java/memoryModel/DoubleCheckedLocking.html
> Maybe....
> 'volatile' keyword more than anything else.
That article is mostly in the context of the JAVA memory model, but any SMP
system, and any standard compliant optimizing C compiler is a far less
certain environment.
http://groups.google.com/groups?selm=MPG.191efc0a3bf86e2e9896e0%40news.hevan
et.com
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&oe=UTF-8&threadm=3ec8e247
%40usenet01.boi.hp.com&rnum=1&prev=/groups%3Fq%3DDavid%2BButenhof%2Bdouble%2
Bchecked%2Block%26hl%3Den%26lr%3D%26ie%3DUTF-8%26oe%3DUTF-8%26selm%3D3ec8e24
7%2540usenet01.boi.hp.com%26rnum%3D1
Jeff
--- End Message ---
> same source file as the iocshVarDef and to specify the 'extern' in the
> source file where it's now being declared, right?
That *is* a possible solution (which I didnt consider) although this may be
somewhat unweildy from a code structure veiw point. Someone might ask "where
is that I go to find the definitions of variables that are used by subsystem
pdq". Also, I generally try to have a hierarchical design (a tree net) when
libraries link with each other. That is, its probably best not to have
library A referencing symbols in library B while at the same time library B
references symbols in library A. No problem with one or the other but both
can get messy.
Jeff
--- End Message ---
This is getting messy. Let's consider what we are doing now and think about what
may be wrong.
At issue are iocshVarDef and epicsExportAddress
First consider iocshVarDef
typedef struct iocshVarDef {
const char *name;
iocshArgType type;
void * pval;
}iocshVarDef;
The definition for pval should be
void * const pval;
Because it really really is a constant pointer to a non constant.
This also means the the perl script that generates
xxx_registerRecordDeviceDriver.cpp must also cast to (void * const).
I will guess that this will solve the problem Jeff encountered on win32.
Now consider epicsExportAddress
epicsExportAddress(typ,obj) generates the following
epicsShareExtern typ *pobj;
epicsShareDef typ *pobj;
Each of the following in an xxxInclude.dbd file where a application is built
recordtype
device
driver
variable
relies on an epicsShareExtern being defined in a source file.
What can go wrong is that epicsExportAddress could be called with a type that
does not match what is specified in the xxxInclude.dbd file. The easiest one for
the user to get wrong is variable.
For example lets say code has
double xxxTimeout=2.0
epicsExportAddress(double,xxxTimeout)
and the xxxInclude.dbd has
variable(xxxTimeout,int)
No error will be issued when the application is built. But when is variable is
accessed via iocsh bad things happen.
Even the following can happen
code has
epicsExportAddress(rset,aiRSET)
and the Include file has
device(aiRSET)
No error will be generated at build time.
What to do?
Here is a way to ensure that an error is generated at build time (on vxWorks at
ld time).
Let epicsExportAddress(typ,obj) generate the following
epicsShareExtern typ *pobjtyp;
epicsShareDef typ *pobjtyp;
For example
double xxxTimeout=2;
epicsExportAddress(double,xxxTimeout) generates
epicsShareExtern double *pxxxTimeoutdouble;
epicsShareDef double *pxxxTimeoutdouble;
registerRecordDeviceDriver.pl will than generate code that fails at build time
(on vxWorks at ld time) with undefineds if the xxInclude.dbd file mixes types.
Marty
--- End Message ---
For example
After talking to andrew during lunch we are proposing the syntax
epicsShareExtern typ *pvar_type_obj;
epicsShareDef typ *pvar_type_obj;
For example,
epicsShareExtern double *pvar_double_xxxTimeout;
epicsShareDef double *pvar_double_Timeout;
Thus
For now the only allowed values for typ are: rset,dest,drvet, int, double.
Unless I hear objections I will make the appropriate changes to epicsExport.h
and to registerRecordDeviceDriver.pl
I will also change iocsh.h and registerRecordDeviceDriver.pl so that the pval in
iocshVarDef is
void * const pval;
Any comments before I start?
Marty
--- End Message ---
Please see previous message about issues on windows with the linker's
initializing a file scope variable with the address of an exported DLL
symbol which is known only at run time.
Workarounds:
o Let the application create the set / get functions by hand (this allows
application specific range check, locking, change of state processing).
o Computer generate the set and get code (this will work on windows even if
the generated code is not in the exporting DLL because it does not link time
initialize a variable with the address of a symbol exported from a DLL).
This approach allows for compile time knowledge of data type specific range
checking.
o Computer generate a function that returns the symbol's address (this will
work on windows even if the generated code is not in the exporting DLL
because it does not link time initialize a variable with the address of a
o Move the variable to iocsh as Eric suggested (this *will* work, but see my
previous message discussing this).
Jeff
> From: Marty Kraimer [mailto:mrk@aps.anl.gov]
> Sent: Wednesday, February 11, 2004 12:08 PM
> To: Marty Kraimer
> Cc: Jeff Hill; 'Eric Norum'; Andrew Johnson; 'Ralph Lange'
> > For example
> For example,
> Thus
> int, double.
> to epicsExport.h
> so that the pval in
> iocshVarDef is
> void * const pval;
> Marty
--- End Message ---
Workarounds:
checking.
Jeff
I am still not convinced that what I suggest will not work.
Please note that for rset, dset, registrar, and even with variable it worked
with the generated example_registerRecordDeviceDriver.cpp code.
I made and committed changes in src/iocsh and in src/registry so that for pvar
the type is "void * const" instead of "void *". Please do a cvs update and see
if you can now build.
Marty
--- End Message ---
for pvar the type is "void * const" instead of "void *". Please do a cvs
update and see if you can now build.
Marty
I just did another commit to src/iocsh.
I changed {"asCaDebug", iocshArgInt,(void * const )&asCaDebug}
to
{"asCaDebug", iocshArgInt,(void * const )pasCaDebug}
Marty
--- End Message ---
Timestamp (drvTS) progress Korhonen Timo
<2004>
<2004>
