The changes I committed Thursday evening improve the efficiency of
ca_flush() which is called also by ca_pend_event(), ca_pend_io(), and
ca_poll(). The performance differences were not detected by my R3.14
performance tests because their results compared favorably with R3.13,
and because these tests call flush only once at the end of a large set
of IO requests.
I can't provide R3.13 test results at the moment because R3.13 patch
release changes to its build system seem to prevent an R3.13 "catime"
from being built as in the past using the makefile in R3.13's
base/src/ca.
Nevertheless, here are some R3.14 results. The 71 Mbps maximum
throughput is probably a favorable result from a 100 Mbps LAN when CA
client CPU consumption peaks remained at less than 12% on each of two
CPUs. I suspect that the results may be limited by the portable (now
single threaded) ca server running on one of our newer uniprocessor
Linux boxes or possibly by the network interfaces and or switches.
D:\users\hill\epicsDvl\epics\base>catime joh:bill
Testing with 10000 channels named joh:bill
channel connect test
Elapsed Per Item = 0.00007238 sec, 13815.4 Items per sec, 7.3 Mbps
Search tries per chan - mean=1.142600 std dev=0.417690 min=1.000000
max=3.000000
channel name=joh:bill, native type=6, native count=1
pend event test
Elapsed Per Item = 0.00002332 sec, 42883.6 Items per sec
float test
async put test
Elapsed Per Item = 0.00000324 sec, 308700.3 Items per sec, 42.0 Mbps
async get test
Elapsed Per Item = 0.00000371 sec, 269869.6 Items per sec, 71.2 Mbps
synch get test
Elapsed Per Item = 0.00023484 sec, 4258.2 Items per sec, 1.1 Mbps
double test
async put test
Elapsed Per Item = 0.00000264 sec, 379012.5 Items per sec, 51.5 Mbps
async get test
Elapsed Per Item = 0.00000352 sec, 284206.7 Items per sec, 75.0 Mbps
synch get test
Elapsed Per Item = 0.00026464 sec, 3778.8 Items per sec, 1.0 Mbps
string test
async put test
Elapsed Per Item = 0.00000341 sec, 293473.3 Items per sec, 49.3 Mbps
async get test
Elapsed Per Item = 0.00000545 sec, 183500.7 Items per sec, 54.3 Mbps
synch get test
Elapsed Per Item = 0.00027926 sec, 3580.9 Items per sec, 1.1 Mbps
integer test
async put test
Elapsed Per Item = 0.00000267 sec, 374066.7 Items per sec, 50.9 Mbps
async get test
Elapsed Per Item = 0.00000351 sec, 285104.6 Items per sec, 75.3 Mbps
synch get test
Elapsed Per Item = 0.00024215 sec, 4129.6 Items per sec, 1.1 Mbps
round trip jitter test
Round trip get delays - mean=0.000253 sec, std dev=0.000176 sec,
min=0.000206 se
c max=0.008954 sec
free test
Elapsed Per Item = 0.00000157 sec, 637174.2 Items per sec, 0.0 Mbps
Jeff
> -----Original Message-----
> From: Marty Kraimer [mailto:mrk@aps.anl.gov]
> Sent: Tuesday, January 21, 2003 7:26 AM
> To: Jeff Hill; Johnson, Andrew N.
> Cc: Kenneth Evans, Jr.
> Subject: Re: MEDM 3.13 vs. 3.14
> I ran the dbcaPerform test without running changeLinks.
> This is on a 68040 vxWorks ioc.
> On 3.13 it was 44% idle and on 3.14 it was only 25% idle.
> Here is the breakdown
> R3_13
> tSpyTask spyComTask 8aa734 5 2% ( 169) 2%
> ( 17)
> tNetTask netTask f57408 50 2% ( 212) 3%
> ( 23)
> scan60 c8a4a0 75 7% ( 572) 7%
> ( 53)
> cbLow callbackTa ec10f4 85 25% ( 1983) 23%
> ( 170)
> dbCaLink dbCaTask eb4bf0 88 11% ( 930) 11%
> ( 85)
> cpuUsageTask eb1bc8 255 12% ( 946) 0%
> ( 0)
> KERNEL 0% ( 68) 3%
> ( 23)
> INTERRUPT 0% ( 71) 2%
> ( 15)
> IDLE 35% ( 2787) 44% (
> R3_14
> tSpyTask spyComTask 763af0 5 2% ( 32) 4%
> ( 32)
> tNetTask netTask f57408 50 1% ( 17) 1%
> ( 12)
> scan1 90a8c0 136 12% ( 156) 11%
> ( 92)
> cbLow ebb3c4 140 33% ( 426) 34%
> ( 265)
> CAC-TCP-send 8c9a98 147 1% ( 16) 1%
> ( 8)
> dbCaLink eaecf8 149 10% ( 129) 10%
> ( 81)
> CAC-TCP-recv 8cc748 150 8% ( 114) 9%
> ( 70)
> IDLE 28% ( 358) 25%
> ( 197)
> TOTAL 95% ( 1268) 95%
> ( 768)
> NOTE that cbLow does CA puts to the other ioc.
> I think this test also indicates that CA is using lots more CPU
> TIME.
> Marty
- Re: MEDM 3.13 vs. 3.14 Janet Anderson
new caEventRate diagnostic Jeff Hill
<2003>
<2003>
