In the following I have only looked at changes for long, unsigned long, and enums.
I have modified the following files (all in <base>/src)
ca/db_access.h
Just added some ifdefs so that db_access.c can get it's structure definitions
from this file.
libCom/cvtFast/cvtFast.*
long => epicsInt32
unsigned long=> epicsUInt32
dbStatic/dbToRecordtypeH.c
In generated include files the following field definitions are changed
long => epicsInt32
unsigned shot=> epicsEnum16 (for DBF_ENUM,DBF_MENU,DBF_DEVICE)
db/db_access.c
Get structure defs from db_access.h
short => dbr_short_t OR dbr_enum_t as necessary
float => dbr_float_t
char => dbr_char_t
long => dbr_long_t
double => dbr_double_t
dbAccessDefs.h
replace elementary types with epics types, e.g. long=>epicsInt32
dbConvert.c and dbFastLinkConv.c
replaced all enums from unsigned short to epicsEnum16
rplaced long by epicsInt32
replaced unsigned long by epicsUInt32
I am attaching a complete list of the diffs.
Questions
1) What about all the other defs like float=>epicsFloat32 ?
2) What about all the other uses of long in base?
3) What about long for no_elements in dbAddr.h
4) Have I already gone too far?
Marty
Index: ca/db_access.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/ca/db_access.h,v
retrieving revision 1.13
diff -r1.13 db_access.h
62a63
> #ifndef db_accessHFORdb_accessC
180c181
> #endif /*db_accessHFORdb_accessC*/
526a528
732a735
Index: db/dbAccessDefs.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/dbAccessDefs.h,v
retrieving revision 1.9
diff -r1.9 dbAccessDefs.h
15a16,21
> #ifdef epicsExportSharedSymbols
> # define INCLdb_accessh_epicsExportSharedSymbols
> # undef epicsExportSharedSymbols
> #endif
> #include "epicsTypes.h"
17c23,28
< #include "shareLib.h"
> #ifdef INCLdb_accessh_epicsExportSharedSymbols
> # define epicsExportSharedSymbols
> # include "shareLib.h"
> #endif
48c59
< * float value[10]
> * epicsFloat32 value[10]
81c92
< * float value[10]
92,95c103,106
< unsigned short status; /* alarm status */\
< unsigned short severity; /* alarm severity*/\
< unsigned short acks; /* alarm ack severity*/\
< unsigned short ackt; /* Acknowledge transient alarms?*/
> epicsUInt16 status; /* alarm status */\
> epicsUInt16 severity; /* alarm severity*/\
> epicsUInt16 acks; /* alarm ack severity*/\
> epicsUInt16 ackt; /* Acknowledge transient alarms?*/
100,101c111,112
< long precision; /* number of decimal places*/\
< long field_width; /* field width */
> epicsInt32 precision; /* number of decimal places*/\
> epicsInt32 field_width; /* field width */
105,106c116,117
< unsigned long no_str; /* number of strings*/\
< long padenumStrs; /*padding to force 8 byte align*/\
> epicsUInt32 no_str; /* number of strings*/\
> epicsInt32 padenumStrs; /*padding to force 8 byte align*/\
109,110c120,121
< long upper_disp_limit; /*upper limit of graph*/\
< long lower_disp_limit; /*lower limit of graph*/
> epicsInt32 upper_disp_limit; /*upper limit of graph*/\
> epicsInt32 lower_disp_limit; /*lower limit of graph*/
112,113c123,124
< double upper_disp_limit; /*upper limit of graph*/\
< double lower_disp_limit; /*lower limit of graph*/
> epicsFloat64 upper_disp_limit; /*upper limit of graph*/\
> epicsFloat64 lower_disp_limit; /*lower limit of graph*/
115,116c126,127
< long upper_ctrl_limit; /*upper limit of graph*/\
< long lower_ctrl_limit; /*lower limit of graph*/
> epicsInt32 upper_ctrl_limit; /*upper limit of graph*/\
> epicsInt32 lower_ctrl_limit; /*lower limit of graph*/
118,119c129,130
< double upper_ctrl_limit; /*upper limit of graph*/\
< double lower_ctrl_limit; /*lower limit of graph*/
> epicsFloat64 upper_ctrl_limit; /*upper limit of graph*/\
> epicsFloat64 lower_ctrl_limit; /*lower limit of graph*/
121,124c132,135
< long upper_alarm_limit;\
< long upper_warning_limit;\
< long lower_warning_limit;\
< long lower_alarm_limit;
> epicsInt32 upper_alarm_limit;\
> epicsInt32 upper_warning_limit;\
> epicsInt32 lower_warning_limit;\
> epicsInt32 lower_alarm_limit;
126,129c137,140
< double upper_alarm_limit;\
< double upper_warning_limit;\
< double lower_warning_limit;\
< double lower_alarm_limit;
> epicsFloat64 upper_alarm_limit;\
> epicsFloat64 upper_warning_limit;\
> epicsFloat64 lower_warning_limit;\
> epicsFloat64 lower_alarm_limit;
Index: db/dbConvert.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/dbConvert.c,v
retrieving revision 1.17
diff -r1.17 dbConvert.c
238c238
< long *pbuffer = (long *)pto;
> epicsInt32 *pbuffer = (epicsInt32 *)pto;
240c240
< long value;
> epicsInt32 value;
243c243
< if(sscanf(psrc,"%ld",&value) == 1) {
> if(sscanf(psrc,"%d",&value) == 1) {
255c255
275,277c275,277
< unsigned long *pbuffer = (unsigned long *)pto;
< char *psrc=(char *)paddr->pfield;
< double value;
> epicsUInt32 *pbuffer = (epicsUInt32 *)pto;
> double value;
283c283
< *pbuffer = (unsigned long)value;
> *pbuffer = (epicsUInt32)value;
295c295
493c493
512c512
569c569
< unsigned short *pbuffer = (unsigned short *)pto;
> epicsEnum16 *pbuffer = (epicsEnum16 *)pto;
687c687
706c706
763c763
880c880
899c899
956c956
1073c1073
1092c1092
1149c1149
1169c1169
< long *psrc=(long *)(paddr->pfield);
> epicsInt32 *psrc=(epicsInt32 *)(paddr->pfield);
1180c1180
< psrc=(long *)paddr->pfield;
> psrc=(epicsInt32 *)paddr->pfield;
1192c1192
1201c1201
< if(++offset==no_elements) psrc=(long *)paddr->pfield;
> if(++offset==no_elements) psrc=(epicsInt32 *)paddr->pfield;
1211c1211
1220c1220
1230c1230
1239c1239
1249c1249
1258c1258
1267,1268c1267,1268
1277c1277
1286,1287c1286,1287
1296c1296
1306c1306
1315c1315
1325c1325
1334c1334
1343,1344c1343,1344
1353c1353
1363c1363
< unsigned long *psrc=(unsigned long *)(paddr->pfield);
> epicsUInt32 *psrc=(epicsUInt32 *)(paddr->pfield);
1374c1374
< psrc=(unsigned long *)paddr->pfield;
> psrc=(epicsUInt32 *)paddr->pfield;
1386c1386
1395c1395
< if(++offset==no_elements) psrc=(unsigned long *)paddr->pfield;
> if(++offset==no_elements) psrc=(epicsUInt32 *)paddr->pfield;
1405c1405
1414c1414
1424c1424
1433c1433
1443c1443
1452c1452
1461,1462c1461,1462
1471c1471
1480,1481c1480,1481
1490c1490
1500c1500
1509c1509
1519c1519
1528c1528
1537,1538c1537,1538
1547c1547
1661c1661
1680c1680
1737c1737
1861c1861
1880c1880
1938c1938
1972c1972
< unsigned short *psrc=(unsigned short *)(paddr->pfield);
> epicsEnum16 *psrc=(epicsEnum16 *)(paddr->pfield);
1981c1981
< if(++offset==no_elements) psrc=(unsigned short *)paddr->pfield;
> if(++offset==no_elements) psrc=(epicsEnum16 *)paddr->pfield;
1991c1991
2000c2000
2010c2010
2019c2019
2029c2029
2038c2038
2047,2048c2047,2048
2057c2057
2066,2067c2066,2067
2076c2076
2086c2086
2095c2095
2105c2105
2114c2114
2123,2124c2123,2124
2133c2133
2147c2147
< unsigned short choice_ind= *((unsigned short*)paddr->pfield);
> epicsEnum16 choice_ind= *((epicsEnum16*)paddr->pfield);
2173c2173
2476c2476
< unsigned short *pfield= (unsigned short*)(paddr->pfield);
> epicsEnum16 *pfield= (epicsEnum16*)(paddr->pfield);
2519c2519
2556c2556
2766c2766
< unsigned short *pdest=(unsigned short *)(paddr->pfield);
> epicsEnum16 *pdest=(epicsEnum16 *)(paddr->pfield);
2775c2775
< if(++offset==no_elements) pdest=(unsigned short *)paddr->pfield;
> if(++offset==no_elements) pdest=(epicsEnum16 *)paddr->pfield;
2962c2962
2971c2971
3158c3158
3167c3167
3278c3278
< long *pdest=(long *)(paddr->pfield);
> epicsInt32 *pdest=(epicsInt32 *)(paddr->pfield);
3287c3287
< if(++offset==no_elements) pdest=(long *)paddr->pfield;
> if(++offset==no_elements) pdest=(epicsInt32 *)paddr->pfield;
3297c3297
< unsigned long *pdest=(unsigned long *)(paddr->pfield);
> epicsUInt32 *pdest=(epicsUInt32 *)(paddr->pfield);
3306c3306
< if(++offset==no_elements) pdest=(unsigned long *)paddr->pfield;
> if(++offset==no_elements) pdest=(epicsUInt32 *)paddr->pfield;
3354c3354
3363c3363
3372c3372
< long *pbuffer = (long *)pfrom;
> epicsInt32 *pbuffer = (epicsInt32 *)pfrom;
3397c3397
3416c3416
3435c3435
3454c3454
3473,3474c3473,3474
3483c3483
3492,3493c3492,3493
3502c3502
3511c3511
3530c3530
3549,3550c3549,3550
3559c3559
3568c3568
< unsigned long *pbuffer = (unsigned long *)pfrom;
> epicsUInt32 *pbuffer = (epicsUInt32 *)pfrom;
3593c3593
3612c3612
3631c3631
3650c3650
3669,3670c3669,3670
3679c3679
3688,3689c3688,3689
3698c3698
3707c3707
3726c3726
3745,3746c3745,3746
3755c3755
3871c3871
3880c3880
3890c3890
3899c3899
3947c3947
3956c3956
4072c4072
4081c4081
4091c4091
4100c4100
4149c4149
4158c4158
4167c4167
< unsigned short *pbuffer = (unsigned short *)pfrom;
> epicsEnum16 *pbuffer = (epicsEnum16 *)pfrom;
4192c4192
4211c4211
4230c4230
4249c4249
4268,4269c4268,4269
4278c4278
4287,4288c4287,4288
4297c4297
4306c4306
4325c4325
4344,4345c4344,4345
4354c4354
Index: db/dbFastLinkConv.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/dbFastLinkConv.c,v
retrieving revision 1.22
diff -r1.22 dbFastLinkConv.c
171c171
< long *to,
> epicsInt32 *to,
174c174
< long value;
> epicsInt32 value;
176c176
< if (sscanf(from, "%ld", &value) == 1) {
> if (sscanf(from, "%d", &value) == 1) {
191c191
< unsigned long *to,
> epicsUInt32 *to,
199c199
< *to = (unsigned long)value;
> *to = (epicsUInt32)value;
253c253
< unsigned short *to,
> epicsEnum16 *to,
258c258
295c295
> epicsEnum16 *to,
327c327
> epicsEnum16 *to,
394c394
< long *to,
> epicsInt32 *to,
401c401
> epicsUInt32 *to,
422c422
> epicsEnum16 *to,
464c464
< long *to,
> epicsInt32 *to,
471c471
> epicsUInt32 *to,
492c492
> epicsEnum16 *to,
534c534
< long *to,
> epicsInt32 *to,
541c541
> epicsUInt32 *to,
562c562
> epicsEnum16 *to,
604c604
< long *to,
> epicsInt32 *to,
611c611
> epicsUInt32 *to,
638c638
< long *from,
> epicsInt32 *from,
645c645
< long *from,
> epicsInt32 *from,
652c652
< long *from,
> epicsInt32 *from,
659c659
< long *from,
> epicsInt32 *from,
666c666
< long *from,
> epicsInt32 *from,
673,674c673,674
< long *from,
< long *to,
> epicsInt32 *from,
> epicsInt32 *to,
680,681c680,681
< long *from,
> epicsInt32 *from,
> epicsUInt32 *to,
687c687
< long *from,
> epicsInt32 *from,
694c694
< long *from,
> epicsInt32 *from,
701,702c701,702
< long *from,
> epicsInt32 *from,
> epicsEnum16 *to,
708c708
< unsigned long *from,
> epicsUInt32 *from,
715c715
> epicsUInt32 *from,
722c722
> epicsUInt32 *from,
729c729
> epicsUInt32 *from,
736c736
> epicsUInt32 *from,
743,744c743,744
< long *to,
> epicsUInt32 *from,
> epicsInt32 *to,
750,751c750,751
> epicsUInt32 *from,
> epicsUInt32 *to,
757c757
> epicsUInt32 *from,
764c764
> epicsUInt32 *from,
771,772c771,772
> epicsUInt32 *from,
> epicsEnum16 *to,
825c825
< long *to,
> epicsInt32 *to,
832c832
> epicsUInt32 *to,
853c853
> epicsEnum16 *to,
906c906
< long *to,
> epicsInt32 *to,
913c913
> epicsUInt32 *to,
946c946
> epicsEnum16 *to,
952c952
< unsigned short *from,
> epicsEnum16 *from,
959c959
> epicsEnum16 *from,
966c966
> epicsEnum16 *from,
973c973
> epicsEnum16 *from,
980,981c980,981
< long *to,
> epicsEnum16 *from,
> epicsInt32 *to,
987,988c987,988
> epicsEnum16 *from,
> epicsUInt32 *to,
994c994
> epicsEnum16 *from,
1001c1001
> epicsEnum16 *from,
1008,1009c1008,1009
> epicsEnum16 *from,
> epicsEnum16 *to,
1017c1017
> epicsEnum16 *from,
1037c1037
> epicsEnum16 *from,
1044c1044
> epicsEnum16 *from,
1069c1069
> epicsEnum16 *from,
Index: db/dbTest.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/dbTest.c,v
retrieving revision 1.83
diff -r1.83 dbTest.c
802c802
< printf("precision=%ld\n", pdbr_precision->precision);
> printf("precision=%d\n", pdbr_precision->precision);
823c823
< printf("no_strs=%lu\n", pdbr_enumStrs->no_str);
> printf("no_strs=%u\n", pdbr_enumStrs->no_str);
834c834
< printf("grLong: %ld %ld\n",pdbr_grLong->upper_disp_limit,
> printf("grLong: %d %d\n",pdbr_grLong->upper_disp_limit,
856c856
< printf("ctrlLong: %ld %ld\n",pdbr_ctrlLong->upper_ctrl_limit,
> printf("ctrlLong: %d %d\n",pdbr_ctrlLong->upper_ctrl_limit,
878c878
< printf("alLong: %ld %ld %ld %ld\n",
> printf("alLong: %d %d %d %d\n",
Index: db/db_access.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/db_access.c,v
retrieving revision 1.46
diff -r1.46 db_access.c
41a42,44
> #define db_accessHFORdb_accessC
> #include "db_access.h"
> #undef db_accessHFORdb_accessC
108c111
< /*Following is defined in db_access.h*/
> /*Following is defined in dbConvert.h*/
118,465d120
< #ifndef MAX_UNITS_SIZE
< #define MAX_UNITS_SIZE 8
< #endif
< /* VALUES WITH STATUS STRUCTURES */
< /* structure for a string status field */
< struct dbr_sts_string{
< short status; /* status of value */
< short severity; /* severity of alarm */
< char value[MAX_STRING_SIZE]; /* current value */
< struct dbr_stsack_string{
< unsigned short status; /* status of value */
< unsigned short severity; /* severity of alarm */
< unsigned short ackt; /* ack transient? */
< unsigned short acks; /* ack severity */
< /* structure for an short status field */
< struct dbr_sts_int{
< short value; /* current value */
< struct dbr_sts_short{
< /* structure for a float status field */
< struct dbr_sts_float{
< float value; /* current value */
< /* structure for a enum status field */
< struct dbr_sts_enum{
< /* structure for a char status field */
< struct dbr_sts_char{
< char RISC_pad; /* RISC alignment */
< unsigned char value; /* current value */
< /* structure for a long status field */
< struct dbr_sts_long{
< long value; /* current value */
< /* structure for a double status field */
< struct dbr_sts_double{
< long RISC_pad; /* RISC alignment */
< double value; /* current value */
< /* VALUES WITH STATUS AND TIME STRUCTURES */
< /* structure for a string time field */
< struct dbr_time_string{
< epicsTimeStamp stamp; /* time stamp */
< /* structure for an short time field */
< struct dbr_time_short{
< short RISC_pad; /* RISC alignment */
< /* structure for a float time field */
< struct dbr_time_float{
< /* structure for a enum time field */
< struct dbr_time_enum{
< /* structure for a char time field */
< struct dbr_time_char{
< short RISC_pad0; /* RISC alignment */
< char RISC_pad1; /* RISC alignment */
< /* structure for a long time field */
< struct dbr_time_long{
< /* structure for a double time field */
< struct dbr_time_double{
< /* VALUES WITH STATUS AND GRAPHIC STRUCTURES */
< /* structure for a graphic string */
< /* not implemented; use struct_dbr_sts_string */
< /* structure for a graphic short field */
< struct dbr_gr_int{
< char units[MAX_UNITS_SIZE]; /* units of value */
< short upper_disp_limit; /* upper limit of graph */
< short lower_disp_limit; /* lower limit of graph */
< short upper_alarm_limit;
< short upper_warning_limit;
< short lower_warning_limit;
< short lower_alarm_limit;
< struct dbr_gr_short{
< /* structure for a graphic floating point field */
< struct dbr_gr_float{
< short precision; /* number of decimal places */
< float upper_disp_limit; /* upper limit of graph */
< float lower_disp_limit; /* lower limit of graph */
< float upper_alarm_limit;
< float upper_warning_limit;
< float lower_warning_limit;
< float lower_alarm_limit;
< /* structure for a graphic enumeration field */
< struct dbr_gr_enum{
< short no_str; /* number of strings */
< char strs[16][26]; /* state strings */
< /* structure for a graphic char field */
< struct dbr_gr_char{
< unsigned char upper_disp_limit; /* upper limit of graph */
< unsigned char lower_disp_limit; /* lower limit of graph */
< unsigned char upper_alarm_limit;
< unsigned char upper_warning_limit;
< unsigned char lower_warning_limit;
< unsigned char lower_alarm_limit;
< /* structure for a graphic long field */
< struct dbr_gr_long{
< long upper_disp_limit; /* upper limit of graph */
< long lower_disp_limit; /* lower limit of graph */
< /* structure for a graphic double field */
< struct dbr_gr_double{
< double upper_disp_limit; /* upper limit of graph */
< double lower_disp_limit; /* lower limit of graph */
< /* VALUES WITH STATUS, GRAPHIC and CONTROL STRUCTURES */
< /* structure for a control string */
< /* structure for a control integer */
< struct dbr_ctrl_int{
< short upper_ctrl_limit; /* upper control limit */
< short lower_ctrl_limit; /* lower control limit */
< struct dbr_ctrl_short{
< /* structure for a control floating point field */
< struct dbr_ctrl_float{
< float upper_ctrl_limit; /* upper control limit */
< float lower_ctrl_limit; /* lower control limit */
< /* structure for a control enumeration field */
< struct dbr_ctrl_enum{
< /* structure for a control char field */
< struct dbr_ctrl_char{
< unsigned char upper_ctrl_limit; /* upper control limit */
< unsigned char lower_ctrl_limit; /* lower control limit */
< /* structure for a control long field */
< struct dbr_ctrl_long{
< long upper_ctrl_limit; /* upper control limit */
< long lower_ctrl_limit; /* lower control limit */
< /* structure for a control double field */
< struct dbr_ctrl_double{
< double upper_ctrl_limit; /* upper control limit */
< double lower_ctrl_limit; /* lower control limit */
619c274
< short *pvalue = (short *)pbuffer;
> dbr_short_t *pvalue = (dbr_short_t *)pbuffer;
630c285
< float *pvalue = (float *)pbuffer;
> dbr_float_t *pvalue = (dbr_float_t *)pbuffer;
641c296
> dbr_enum_t *pvalue = (dbr_enum_t *)pbuffer;
652c307
< char *pvalue = (char *)pbuffer;
> dbr_char_t *pvalue = (dbr_char_t *)pbuffer;
663c318
< long *pvalue = (long *)pbuffer;
> dbr_long_t *pvalue = (dbr_long_t *)pbuffer;
674c329
< double *pvalue = (double *)pbuffer;
> dbr_double_t *pvalue = (dbr_double_t *)pbuffer;
713c368
< short *pvalue = &pold->value;
> dbr_short_t *pvalue = &pold->value;
734c389
< float *pvalue = &pold->value;
> dbr_float_t *pvalue = &pold->value;
755c410
> dbr_enum_t *pvalue = &pold->value;
776c431
< unsigned char *pvalue = &pold->value;
> dbr_char_t *pvalue = &pold->value;
797c452
< long *pvalue = &pold->value;
> dbr_long_t *pvalue = &pold->value;
818c473
< double *pvalue = &pold->value;
> dbr_double_t *pvalue = &pold->value;
864c519
887c542
910c565
933c588
956c611
979c634
1006c661
1039c694
1074c729
1106c761
1139c794
1175c830
1212c867
1248c903
1281c936
1317c972
1353c1008
Index: dbStatic/dbToRecordtypeH.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/dbStatic/dbToRecordtypeH.c,v
diff -r1.22 dbToRecordtypeH.c
123a124
> fprintf(outFile,"#include \"epicsTypes.h\"\n");
175c176
< fprintf(outFile,"\tlong\t\t%s;\t/*%s*/\n",
> fprintf(outFile,"\ttepicsInt32\t\t%s;\t/*%s*/\n",
193c194
< fprintf(outFile,"\tunsigned short\t%s;\t/*%s*/\n",
> fprintf(outFile,"\tepicsEnum16\t%s;\t/*%s*/\n",
Index: libCom/cvtFast/cvtFast.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/cvtFast/cvtFast.c,v
retrieving revision 1.32
diff -r1.32 cvtFast.c
38c38
< static long frac_multiplier[] =
> static epicsInt32 frac_multiplier[] =
47c47
< long whole,iplace,number,fraction,fplace;
> epicsInt32 whole,iplace,number,fraction,fplace;
65c65
< whole = (long)flt_value;
> whole = (epicsInt32)flt_value;
70c70
< fraction = (long)(ftemp * fplace * 10);
> fraction = (epicsInt32)(ftemp * fplace * 10);
121c121
146c146
151c151
404c404
< long source,
> epicsInt32 source,
407c407
< long val,temp;
> epicsInt32 val,temp;
418,419c418,419
< if(source == LONG_MIN) {
< sprintf(pdest,"%ld",source);
> if(source == INT_MIN) {
> sprintf(pdest,"%d",source);
440c440
< unsigned long source,
> epicsUInt32 source,
443c443
< unsigned long val,temp;
> epicsUInt32 val,temp;
474c474
< long source,
> epicsInt32 source,
477c477
< long val,temp;
488,489c488,489
< sprintf(pdest,"-0x%lx",source);
> sprintf(pdest,"-0x%x",source);
511c511
< long source,
> epicsInt32 source,
514c514
< long val,temp;
525,526c525,526
< sprintf(pdest,"-0%lo",source);
> sprintf(pdest,"-0%o",source);
554c554
< * extract a bit field from the source unsigend long
> * extract a bit field from the source epicsUInt32
556,557c556,557
< unsigned long epicsShareAPI cvtBitsToUlong(
< unsigned long src,
> epicsUInt32 epicsShareAPI cvtBitsToUlong(
> epicsUInt32 src,
561c561
< unsigned long mask;
> epicsUInt32 mask;
578,579c578,579
< * insert a bit field from the source unsigend long
< * into the destination unsigned long
> * insert a bit field from the source epicsUInt32
> * into the destination epicsUInt32
581,583c581,583
< unsigned long epicsShareAPI cvtUlongToBits(
< unsigned long dest,
> epicsUInt32 epicsShareAPI cvtUlongToBits(
> epicsUInt32 src,
> epicsUInt32 dest,
587c587
> epicsUInt32 mask;
Index: libCom/cvtFast/cvtFast.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/cvtFast/cvtFast.h,v
retrieving revision 1.6
diff -r1.6 cvtFast.h
28a29
60c61
< cvtLongToString(long value, char *pstring);
> cvtLongToString(epicsInt32 value, char *pstring);
62c63
< cvtUlongToString(unsigned long value, char *pstring);
> cvtUlongToString(epicsUInt32 value, char *pstring);
64c65
< cvtLongToHexString(long value, char *pstring);
> cvtLongToHexString(epicsInt32 value, char *pstring);
66,68c67,69
< cvtLongToOctalString(long value, char *pstring);
< epicsShareFunc unsigned long epicsShareAPI cvtBitsToUlong(
> cvtLongToOctalString(epicsInt32 value, char *pstring);
> epicsShareFunc epicsUInt32 epicsShareAPI cvtBitsToUlong(
> epicsUInt32 src,
71,73c72,74
< epicsShareFunc unsigned long epicsShareAPI cvtUlongToBits(
> epicsShareFunc epicsUInt32 epicsShareAPI cvtUlongToBits(
> epicsUInt32 src,
> epicsUInt32 dest,
- RE: RISC_pad in dbr_time_double Jeff Hill
Re: RISC_pad in dbr_time_double Marty Kraimer
<2002>
<2002>
