Eric Norum wrote:
Maybe something like:
static const unsigned epicsThreadPriorityIocsh = 91;
static const unsigned epicsThreadPriorityNetworkDaemons = 95;
static const unsigned epicsThreadPriorityBaseMax = 91; <<<Still
waiting for you folks to come up with a better name... >>>
Then EPICS applications could still have priorities higher than the
shell but lower than the network daemons, or even priorities higher than
the network daemons as necessary.
Why not just have
Then iocsh could just use this as it's priority.
epicsThreadPriorityNetworkDaemons doesn't sound like an epics base issue. It is
an OS epecific issue, e.g. it is an RTEMS issue. If we add it it will, at least
for now, be used only for RTEMS. Does it even make sense for systems where
iocCore is running in user space? Thus at leats for now it will only apply to RTEMS.
On vxWorks I am really afraid of allowing any user thread to be higher priority
than the network threads. This caused failures in the past.
Marty
- RE: base max thread priority Jeff Hill
- Re: base max thread priority Eric Norum
Re: Gateway Ned D. Arnold
<2002>
<2002>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
