On Wednesday, November 27, 2002, at 06:36 AM, Marty Kraimer wrote:
This is a comment about vxWorks and a question about RTEMS.
On vxWorks the following is done:
/* Just map osi 0 to 99 into vx 100 to 199 */
/* remember that for vxWorks lower number means higher priority */
/* vx = 100 + (99 -osi) = 199 - osi*/
/* osi = 199 - vx */
Since the network tasks, etc all have vxWorks priorities < 100 there
is no chance an epics thread can be created with a priortity >
important vxWorks threads.
What is the range of priorities for RTEMS?
1 to 255 (1 highest, 255 lowest). Just like vxWorks.
Comment. It seem to me that a system with severe real time
requirements should not use BSD style networking. But I guess that the
key to implementing severe real time systems is to carefully decide
what it must do and don't let it do anything else.
When I ported the BSD network stack to RTEMS I was very careful to
ensure that the network routines would work properly even when called
from, or used in the presence of, tasks at lower, equal, or higher
priority. I think that it's entirely reasonable for an application to
have tasks at a higher priority than the network tasks. As long as the
higher priority tasks yield enough of the processor to get network work
done and as long as the higher priority tasks make no network calls (or
are aware that they may block when doing so) there will be no problems.
I can think of lots of closed-loop feedback control applications that
would work very well in this mode.
Maybe something like:
static const unsigned epicsThreadPriorityIocsh = 91;
static const unsigned epicsThreadPriorityNetworkDaemons = 95;
static const unsigned epicsThreadPriorityBaseMax = 91; <<<Still
waiting for you folks to come up with a better name... >>>
Then EPICS applications could still have priorities higher than the
shell but lower than the network daemons, or even priorities higher
than the network daemons as necessary.
Eric Norum <[email protected]>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394 FAX: (306) 966-5407
- Re: base max thread priority Marty Kraimer
- RE: base max thread priority Jeff Hill
- Re: base max thread priority Till Straumann
Gateway Marty Kraimer
Re: Gateway Ned D. Arnold
<2002>
<2002>
