Andrew Johnson wrote:
IMO, clamping everyghing to < 91 with the shell running at 91 is safe
- no runaway (base) task can lock the console. However, the user
still has the option of doing really critical work at a higher
priority, if necessary - at the risk of having a locked-up system
should such a task
run away, of course.
... or some other task runs away that owns a resource that the high
priority task needs and has its priority raised through inheritance.
This is still an issue that the application designer should know about
(but beware if that semaphore is hidden behind some OS API...).
Yeah - (although theoretically possible), I consider this rather
unlikely. A RT critical task should only share very 'fast' resources
(i.e. objects that are mutexed for very few lines of code [low runaway
error probability]) with a low priority task. A high priority, RT
critical task who operates on/shares complex resources (doing things
e.g. like printf, malloc or networking) is probably ill-designed.
It might seem prudent to have a control character in the console port's
ISR that can raise the shell's priority in an emergency - I remember we
discussed this idea round the table at JLAB anyway.
Sure - that would be nifty and doable under RTEMS - but what to do under
vxWorks? Another problem is that such a solution is probably highly BSP
specific.
OTOH - rather than building a generic solution into the console ISR [for
multiple OSes/BSPs] that burden could be off-loaded to the user who
really needs the high priority task. For the particular board/OS he/she
uses it's easy to use any IRQ (e.g. a serial line, an onboard switch or
a watchdog) to suspend the critical task on request.
Now another question. RTEMS, and I expect vxWorks as well, have
system tasks handling things like network I/O. What priority should
these run at? At the moment I've got the RTEMS network tasks at
higher than the highest EPICS task priority. From the above
discussions it would seem that running the network tasks at an RTEMS
priority equivalent to EPICS task priority 91 would be the right thing
to do.
From past experience with vxWorks, you probably do not want your
console to be below the network tasks in case nasty things happen that
can lock you out and prevent any chance of debugging.
That makes sense to me.
IIRC, in vxWorks
the only tasks higher than tShell handle message logging and system
callbacks from exceptions (things that can't be done in ISR context).
- Andrew
- Re: base max thread priority Eric Norum
RE: base max thread priority Jeff Hill
Re: base max thread priority Till Straumann
<2002>
<2002>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
