Eric Norum wrote:
On Tuesday, November 26, 2002, at 02:25 PM, Marty Kraimer wrote:
At the EPICS meeting last week Till asked:
1) Could we declare a maximum priority for any component of base?
2) Why does iocsh run at epicsThreadPriorityMax?
Brief discussion.
1) sounds like a good request. How about
epicsThreadPriorityBaseMax = 91
2) I will assume that this was done to be like vxWorks, which runs the
vxWorks shell at highest priority. If iocsh runs at
epicsThreadPriorityBaseMax it seems like it should be OK. If a very
high prority application thread uses all the CPU time iocsh can't get
control but this is the applications problem.
(2) -- I think we did this to ensure that you could still get some
response at the console even if some other task went insane and started
gobbling CPU cycles. With a strict priority-based scheduler like RTEMS
and vxWorks you'd have no possiblity of dealing with such tasks if the
shell were at a lesser or equal priority.
Correct - but this could only happen if the insane task had a priority >
91. However, if the user were to spawn a task with this high a priority,
he/she probably knew what he/she was doing: that task was probably
hard-rt critical and it was not tolerable to have it wait for whatever
was going on at the console.
IMO, clamping everyghing to < 91 with the shell running at 91 is safe
- no runaway (base) task can lock the console. However, the user still
has the option of doing really critical work at a higher priority, if
necessary - at the risk of having a locked-up system should such a task
run away, of course.
The benefit of leaving a range of priorities to the user IMO far
outweighs the possible damage.
-- Till
- Re: base max thread priority Eric Norum
- RE: base max thread priority Jeff Hill
<2002>
<2002>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
