g+
g+ Communities
Argonne National Laboratory
<20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: base max thread priority
To: Eric Norum <eric.norum@usask.ca>
Cc: "Johnson, Andrew N." <anj@aps.anl.gov>, Jeff Hill <johill@lanl.gov>, Till Straumann <strauman@SLAC.Stanford.EDU>
Date: Tue, 26 Nov 2002 14:25:47 -0600
At the EPICS meeting last week Till asked:
1) Could we declare a maximum priority for any component of base?
2) Why does iocsh run at epicsThreadPriorityMax?
Brief discussion.
1) sounds like a good request. How about
epicsThreadPriorityBaseMax = 91
2) I will assume that this was done to be like vxWorks, which runs the vxWorks shell at highest priority. If iocsh runs at epicsThreadPriorityBaseMax it seems like it should be OK. If a very high prority application thread uses all the CPU time iocsh can't get control but this is the applications problem.
Comments anyone?
Marty
Re: base max thread priority Eric Norum
Prev: Re: EPICS Bug Tracker Bob Dalesio
Next: Re: base max thread priority Eric Norum
Index: <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: FW: [EPICS Base R3.14.x 0000018]: gcc 2.95.x crashes on cac.cpp Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
