Hi Geoff,
Geoff Savage wrote:
From your talk at jlab on R3.15 I was not clear on the fate of dbd
files. Will they still exist in R3.15? We use them in our ORACLE
database. I understand how moving the information from the dbd file
into the compiled objects will make things safer on the IOC but getting
the same information into the ORACLE database will be impacted.
DBD files will still required in R3.15 - they are still the fundamental
way in which an IOC's facilities are configured. I'm just converting them
to another form for loading onto the IOC itself.
Note that we are adding new keywords to DBD files though - for R3.14 there
is an additional function() statement which is needed for subroutine
records on non-vxWorks IOCs, and in R3.15 there will be more changes to
add link support. You will probably want to make sure that your Oracle
process can cope with using a different DBD file for each IOC or group of
IOCs.
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
CROSS_COMPILER_TARGET_ARCHS default change Janet Anderson
Re: base max thread priority Andrew Johnson
<2002>
POSIX recursive mutex Marty Kraimer
<2002>
