g+
g+ Communities
Argonne National Laboratory
<20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Gateway
To: Ned Arnold <nda@aps.anl.gov>, evans@aps.anl.gov
Cc: "Johnson, Andrew N." <anj@aps.anl.gov>, Marty Kraimer <mrk@aps.anl.gov>, Ralph Lange <Ralph.Lange@mail.bessy.de>
Date: Wed, 27 Nov 2002 07:47:35 -0600
At the EPICS Core Working Group meeting at JLAB the problem of running the gateway on 3.14 was discussed. My understanding is that when we build the gateway against 3.14 it uses so much cpu time that it doesn't work correctly. Someone mentioned that on 3.13 it already uses 75% of the cpu.
Some questions.
Is this true? Ken should know the answers. Do you have some actual performance numbers?
If this is true then it sounds like only a matter of time until even the 3.13 version will fail.
I assume this only applys to the gateway for ASD not the gateways for the CATS.
For the ASD gateway can't we have another solution?
Some possibilities.
Run separate gatways for phoebus and oxygen.
Get a more powerful gateway machine.
Marty
RE: 3.14 Gateway Performance Kenneth Evans, Jr.
Prev: INET address Marty Kraimer
Next: Re: base max thread priority Eric Norum
Index: <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: RE: INET address Jeff Hill
Next: RE: 3.14 Gateway Performance Kenneth Evans, Jr.
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
