next up previous contents index
Next: 15. Runtime Database Access Up: AppDevGuide Previous: 13. Driver Support   Contents   Index
Subsections
14. Static Database Access
14.1 Overview
An IOC database is created on a Unix system via a Database Configuration Tool and stored in a Unix file. EPICS provides two sets of database access routines: Static Database Access and Runtime Database Access. Static database access can be used on Unix or IOC database files. Runtime database requires an initialized IOC databases. Static database access is described in this chapter, runtime database access in the next chapter.
Static database access provides a simplified interface to a database, i.e. much of the complexity is hidden. DBF_MENU and DBF_DEVICE fields are accessed via a common type called DCT_MENU. A set of routines are provided to simplify access to link fields. All fields can be accessed as character strings. This interface is called static database access because it can be used to access an uninitialized as well as an initialized database.
Before accessing database records, the menus, record types, and devices used to define that IOC database must be read via dbReadDatabase or dbReadDatabaseFP. These routines, which are also used to load record instances, can be called multiple times.
Database Configuration Tools (DCTs) should manipulate an EPICS database only via the static database access interface. An IOC database is created on a host system via a database configuration tool and stored in a host file with a file extension of ``.db". Three routines (dbReadDatabase, dbReadDatabaseFP and dbWriteRecord) access the database file. These routines read/write a database file to/from a memory resident EPICS database. All other access routines manipulate the memory resident database.
An include file dbStaticLib.h contains all the definitions needed to use the static database access library. Two structures (DBBASE and DBENTRY) are used to access a database. The fields in these structures should not be accessed directly. They are used by the static database access library to keep state information for the caller.
14.2 Definitions
14.2.1 DBBASE
Multiple memory resident databases can be accessed simultaneously. The user must provide definitions in the form:
DBBASE *pdbbase;
NOTE: On an IOC pdbbase is a global variable, which is accessable if you include dbAccess.h
14.2.2 DBENTRY
A typical declaration for a database entry structure is:
DBENTRY *pdbentry;
pdbentry=dbAllocEntry(pdbbase);
Most static access to a database is via a DBENTRY structure. As many DBENTRYs as desired can be allocated.
The user should NEVER access the fields of DBENTRY directly. They are meant to be used by the static database access library.
Most static access routines accept an argument which contains the address of a DBENTRY. Each routine uses this structure to locate the information it needs and gives values to as many fields in this structure as possible. All other fields are set to NULL.
14.2.3 Field Types
Each database field has a type as defined in the next chapter. For static database access a simpler set of field types are defined. In addition, at runtime, a database field can be an array. With static database access, however, all fields are scalars. Static database access field types are called DCT field types.
The DCT field types are:
A DCT_STRING field contains the address of a NULL terminated string. The field types DCT_INTEGER and DCT_REAL are used for numeric fields. A field that has any of these types can be accessed via the dbGetString, dbPutString, dbVerify, and dbGetRange routines.
The field type DCT_MENU has an associated set of strings defining the choices. Routines are available for accessing menu fields. A menu field can also be accessed via the dbGetString, dbPutString, dbVerify, and dbGetRange routines.
The field type DCT_MENUFORM is like DCT_MENU but in addition the field has an associated link field.
DCT_INLINK (input), DCT_OUTLINK (output), and DCT_FWDLINK (forward) specify that the field is a link, which has an associated set of static access routines described in the next subsection. A field that has any of these types can also be accessed via the dbGetString, dbPutString, dbVerify, and dbGetRange routines.
14.3 Allocating and Freeing DBBASE
14.3.1 dbAllocBase
DBBASE *dbAllocBase(void);
This routine allocates and initializes a DBBASE structure. It does not return if it is unable to allocate storage.
Most applications should not need to call this routine directly. The dbReadDatabase and dbReadDatabaseFP routines will call it automatically if pdbbase is null. Thus an application normally only has to contain code like the following:
DBBASE  *pdbbase=0;
status = dbReadDatabase(&pdbbase, dbdfile, search_path, macros);
However the static database access library does allow applications to work with multiple databases simultaneously, each referenced via a different DBBASE pointer. Such applications may need to call dbAllocBase directly.
14.3.2 dbFreeBase
void dbFreeBase(DBBASE *pdbbase);
dbFreeBase frees the entire database reference by pdbbase including the DBBASE structure itself.
14.4 DBENTRY Routines
14.4.1 Alloc/Free DBENTRY
DBENTRY *dbAllocEntry(DBBASE *pdbbase);
void dbFreeEntry(DBENTRY *pdbentry);
These routines allocate, initialize, and free DBENTRY structures. The user can allocate and free DBENTRY structures as necessary. Each DBENTRY is, however, tied to a particular database.
dbAllocEntry and dbFreeEntry act as a pair, i.e. the user calls dbAllocEntry to create a new DBENTRY and calls dbFreeEntry when done.
14.4.2 dbInitEntry dbFinishEntry
void dbInitEntry(DBBASE *pdbbase,DBENTRY *pdbentry);
void dbFinishEntry(DBENTRY *pdbentry);
The routines dbInitEntry and dbFinishEntry are provided in case the user wants to allocate a DBENTRY structure on the stack. Note that the caller MUST call dbFinishEntry before returning from the routine that calls dbInitEntry. An example of how to use these routines is:
int xxx(DBBASE *pdbbase)
    DBENTRY dbentry;
    DBENTRY *pdbentry = &dbentry;
    dbInitEntry(pdbbase,pdbentry);
    dbFinishEntry(pdbentry);
14.4.3 dbCopyEntry
dbCopyEntry
Contents
DBENTRY *dbCopyEntry(DBENTRY *pdbentry);
void dbCopyEntryContents(DBENTRY *pfrom,DBENTRY *pto);
The routine dbCopyEntry allocates a new entry, via a call to dbAllocEntry, copies the information from the original entry, and returns the result. The caller must free the entry, via dbFreeEntry when finished with the DBENTRY.
The routine dbCopyEntryContents copies the contents of pfrom to pto. Code should never perform structure copies.
14.5 Read and Write Database
14.5.1 Read Database File
long dbReadDatabase(DBBASE **ppdbbase,const char *filename,
    char *path, char *substitutions);
long dbReadDatabaseFP(DBBASE **ppdbbase,FILE *fp,
long dbPath(DBBASE *pdbbase,const char *path);
long dbAddPath(DBBASE *pdbbase,const char *path);
dbReadDatabase and dbReadDatabaseFP both read a file containing database definitions as described in chapter "Database Definitions". If *ppdbbase is NULL, dbAllocBase is automatically invoked and the return address assigned to *pdbbase. The only difference between the two routines is that one accepts a file name and the other a "FILE *". Any combination of these routines can be called multiple times. Each adds definitions with the rules described in chapter ``Database Definitions".
The routines dbPath and dbAddPath specify paths for use by include statements in database definition files. These are not normally called by user code.
14.5.2 Write Database Definitons
long dbWriteMenu(DBBASE *pdbbase,char *filename,char *menuName);
long dbWriteMenuFP(DBBASE *pdbbase,FILE *fp,char *menuName);
long dbWriteRecordType(DBBASE *pdbbase,char *filename,char *recordTypeName);
long dbWriteRecordTypeFP(DBBASE *pdbbase,FILE *fp,char *recordTypeName);
long dbWriteDevice(DBBASE *pdbbase,char *filename);
long dbWriteDeviceFP(DBBASE *pdbbase,FILE *fp);
long dbWriteDriver(DBBASE *pdbbase,char *filename);
long dbWriteDriverFP(DBBASE *pdbbase,FILE *fp);
long dbWriteRegistrarFP(DBBASE *pdbbase,FILE *fp);
long dbWriteFunctionFP(DBBASE *pdbbase,FILE *fp);
long dbWriteVariableFP(DBBASE *pdbbase,FILE *fp);
long dbWriteBreaktable(DBBASE *pdbbase,const char *filename);
long dbWriteBreaktableFP(DBBASE *pdbbase,FILE *fp);
Each of these routines writes files in the same format accepted by dbReadDatabase and dbReadDatabaseFP. Two versions of each type are provided. The only difference is that one accepts a filename string and the other a FILE * pointer. Thus only one of each type will be described.
dbWriteMenu writes the description of the specified menu or, if menuName is NULL, the descriptions of all menus.
dbWriteRecordType writes the description of the specified record type or, if recordTypeName is NULL, the descriptions of all record types to the named file.
dbWriteDevice writes the description of all devices to the named file.
dbWriteDriver writes the description of all drivers to the named file.
dbWriteRegistrarFP writes the list of all registrars to the given open file (no filename version is provided).
dbWriteFunctionFP writes the list of all functions to the given open file (no filename version is provided).
dbWriteVariableFP writes the list of all variables to the given open file (no filename version is provided).
dbWriteBreaktable writes the definitions of all breakpoint tables to the named file.
14.5.3 Write Record Instances
long dbWriteRecord(DBBASE *pdbbase,char * file,
char *precordTypeName,int level);
long dbWriteRecordFP(DBBASE *pdbbase,FILE *fp,
These routines write record instance data. If precordTypeName is NULL, then the record instances for all record types are written, otherwise only the records for the specified type are written. level has the following meaning:
14.6 Manipulating Record Types
14.6.1 Get Number of Record Types
int  dbGetNRecordTypes(DBENTRY *pdbentry);
This routine returns the number of record types in the database.
14.6.2 Locate Record Type
long dbFindRecordType(DBENTRY *pdbentry,
long dbFirstRecordType(DBENTRY *pdbentry);
long dbNextRecordType(DBENTRY *pdbentry);
dbFindRecordType locates a particular record type. dbFirstRecordType locates the first, in alphabetical order, record type. Given that DBENTRY points to a particular record type, dbNextRecordType locates the next record type. Each routine returns 0 for success and a non zero status value for failure. A typical code segment using these routines is:
status = dbFirstRecordType(pdbentry);
while(!status) {
    /*Do something*/
    status = dbNextRecordType(pdbentry)
14.6.3 Get Record Type Name
char *dbGetRecordTypeName(DBENTRY *pdbentry);
This routine returns the name of the record type that DBENTRY currently references. This routine should only be called after a successful call to dbFindRecordType, dbFirstRecordType, or dbNextRecordType. It returns NULL if DBENTRY does not point to a record description.
14.7 Manipulating Field Descriptions
The routines described here all assume that DBENTRY references a record type, i.e. that dbFindRecordType, dbFirstRecordType or dbNextRecordType have returned success or that a record instance has been successfully located.
14.7.1 Get Number of Fields
int  dbGetNFields(DBENTRY *pdbentry,int dctonly);
Returns the number of fields for the record instance that DBENTRY currently references.
14.7.2 Locate Field
long dbFirstField(DBENTRY *pdbentry,int dctonly);
long dbNextField(DBENTRY *pdbentry,int dctonly);
These routines are used to locate fields. If any of these routines returns success, then DBENTRY references that field description.
14.7.3 Get Field Type
int  dbGetFieldType(DBENTRY *pdbentry);
This routine returns the integer value for a DCT field type. See Section 14.2.3 for a description of the field types.
14.7.4 Get Field Name
char *dbGetFieldName(DBENTRY *pdbentry);
This routine returns the name of the field that DBENTRY currently references. It returns NULL if DBENTRY does not point to a field.
14.7.5 Get Default Value
char *dbGetDefault(DBENTRY *pdbentry);
This routine returns the default value for the field that DBENTRY currently references. It returns NULL if DBENTRY does not point to a field or if the default value is NULL.
14.7.6 Get Field Prompt
char *dbGetPrompt(DBENTRY *pdbentry);
int   dbGetPromptGroup(DBENTRY *pdbentry);
The dbGetPrompt routine returns the character string prompt value, which provides a short description of the field. dbGetPromptGroup returns the field group as described in guigroup.h.
14.8 Manipulating Record Attributes
A record attribute is a psuedo-field definition attached to a record type. If a attribute value is assigned to a psuedo field name then all record instances of that record type appear to have that field with the defined value. All attribute fields are DCT_STRING fields.
Two field attributes are automatically created: RTYP and VERS. RTYP is set equal to ,the record type name. VERS is initialized to the value ``none specified" but can be changed by record support.
14.8.1 dbPutRecordAttribute
long dbPutRecordAttribute(DBENTRY *pdbentry, const char *name,
    const char *value);
This creates or modifies the attribute name of the record type referenced by pdbentry to value. Attribute names should be valid C identifiers, starting with a letter or underscore followed by any number of alphanumeric or underscore characters.
14.8.2 dbGetRecordAttribute
long dbGetRecordAttribute(DBENTRY *pdbentry, const char *name);
Looks up the attribute name of the record type referenced by pdbentry and sets the the field pointer in pdbentry to refer to this string if it exists. The routine dbGetString can be used subsequently to read the current attribute value.
14.9 Manipulating Record Instances
With the exception of dbFindRecord, each of the routines described in this section need DBENTRY to reference a valid record type, i.e. that dbFindRecordType, dbFirstRecordType, or dbNextRecordType have been called and returned success.
14.9.1 Get Number of Records
int  dbGetNRecords(DBENTRY *pdbentry);
Returns the total number of record instances and aliases for the record type that DBENTRY currently references.
14.9.2 Get Number of Record Aliases
int dbGetNAliases(DBENTRY *pdbentry)
Returns the number of record aliases for the record type that DBENTRY currently references.
14.9.3 Locate Record
long dbFindRecord(DBENTRY *pdbentry,char *precordName);
long dbFirstRecord(DBENTRY *pdbentry);
long dbNextRecord(DBENTRY *pdbentry);
These routines are used to locate record instances and aliases. If any of these routines returns success, then DBENTRY references a record or a record alias (use dbIsAlias to distinguish the two). dbFindRecord may be called without DBENTRY referencing a valid record type. dbFirstRecord only works if DBENTRY references a record type. The dbDumpRecords example given at the end of this chapter shows how these routines can be used.
dbFindRecord also calls dbFindField if the record name includes a field name, i.e. it ends in ``.XXX". The routine dbFoundField indicates whether the field was found or not. If it was not found, then dbFindField must be called before individual fields can be accessed.
14.9.4 Get Record Name
char *dbGetRecordName(DBENTRY *pdbentry);
This routine only works properly if called after dbFindRecord, dbFirstRecord, or dbNextRecord has returned success. If DBENTRY refers to an alias, the name returned is that of the alias, not of the record it refers to.
14.9.5 Distinguishing Record Aliases
int dbIsAlias(DBENTRY *pdbentry)
This routine only works properly if called after dbFindRecord, dbFirstRecord, or dbNextRecord has returned success. If DBENTRY refers to an alias it returns a non-zero value, otherwise it returns zero.
14.9.6 Create/Delete/Free Records and Aliases
long dbCreateRecord(DBENTRY *pdbentry,char *precordName);
long dbCreateAlias(DBENTRY *pdbentry, const char *paliasName);
long dbDeleteRecord(DBENTRY *pdbentry);
long dbDeleteAliases(DBENTRY *pdbentry);
long dbFreeRecords(DBBASE *pdbbase);
dbCreateRecord, which assumes that DBENTRY references a valid record type, creates a new record instance and initializes it as specified by the record description. If it returns success, then DBENTRY references the record just created. dbCreateAlias assumes that DBENTRY references a particular record instance and creates an alias for that record. If it returns success, then DBENTRY references the alias just created. dbDeleteRecord deletes either a single alias, or a single record instance and all the aliases that refer to it. dbDeleteAliases finds and deletes all aliases that refer to the current record. dbFreeRecords deletes all record instances.
14.9.7 Copy Record
long dbCopyRecord(DBENTRY *pdbentry, char *newRecordName
    int overWriteOK)
This routine copies the record instance currently referenced by DBENTRY (it fails if DBENTRY references an alias). Thus it creates a new record with the name newRecordName that is of the same type as the original record and copies the original records field values to the new record. If newRecordName already exists and overWriteOK is true, then the original newRecordName is deleted and recreated. If dbCopyRecord completes successfully, DBENTRY references the new record.
14.9.8 Rename Record
long dbRenameRecord(DBENTRY *pdbentry, char *newname)
This routine renames the record instance currently referenced by DBENTRY (it fails if DBENTRY references an alias). If dbRenameRecord completes successfully, DBENTRY references the renamed record.
14.9.9 Record Visibility
These routines are intended for use by graphical configuration tools.
long dbVisibleRecord(DBENTRY *pdbentry);
long dbInvisibleRecord(DBENTRY *pdbentry);
int dbIsVisibleRecord(DBENTRY *pdbentry);
Calling dbVisibleRecord makes the record referenced by DBENTRY visible. dbInvisibleRecord makes the record invisible. dbIsVisibleRecord returns TRUE if the record is visible, FALSE otherwise.
14.9.10 Find Field
long dbFindField(DBENTRY *pdbentry,char *pfieldName);
int dbFoundField(DBENTRY *pdbentry);
Given that a record instance has been located, dbFindField finds the specified field. If it returns success, then DBENTRY references that field. dbFoundField returns FALSE if no field with the given name could be found, TRUE if the field was located.
14.9.11 Get/Put Field Values
char *dbGetString(DBENTRY *pdbentry);
long dbPutString(DBENTRY *pdbentry,char *pstring);
char *dbVerify(DBENTRY *pdbentry,char *pstring);
char *dbGetRange(DBENTRY *pdbentry);
int   dbIsDefaultValue(DBENTRY *pdbentry);
These routines are used to get or change field values. They work on any database field type except DCT_NOACCESS. dbVerify returns NULL if the string contains a valid value for this field or an error message if not. Note that the strings returned are owned by the DBENTRY, so the next call passing that DBENTRY object that returns a string will overwrite the value returned by a previous call. It is the caller's responsibility to copy the strings if the value must be kept.
DCT_MENU, DCT_MENUFORM and DCT_LINK_xxx fields can be manipulated via routines described in the following sections. If, however dbGetString and dbPutString are used, they do work correctly. For these field types dbGetString and dbPutString are intended to be used only for creating and restoring versions of a database.
14.10 Manipulating Menu Fields
These routines should only be used for DCT_MENU and DCT_MENUFORM fields. Thus they should only be called if dbFindField, dbFirstField, or dbNextField has returned success and the field type is DCT_MENU or DCT_MENUFORM.
14.10.1 Get Number of Menu Choices
int  dbGetNMenuChoices(DBENTRY *pdbentry);
This routine returns the number of menu choices for menu.
14.10.2 Get Menu Choice
char **dbGetMenuChoices(DBENTRY *pdbentry);
This routine returns the address of an array of pointers to strings which contain the menu choices.
14.10.3 Get/Put Menu
int  dbGetMenuIndex(DBENTRY *pdbentry);
long dbPutMenuIndex(DBENTRY *pdbentry,int index);
char *dbGetMenuStringFromIndex(DBENTRY *pdbentry,int index);
int dbGetMenuIndexFromString(DBENTRY *pdbentry,
char *choice);
NOTE: These routines do not work if the current field value contains a macro definition.
dbGetMenuIndex returns the index of the menu choice for the current field, i.e. it specifies which choice to which the field is currently set. dbPutMenuIndex sets the field to the choice specified by the index.
dbGetMenuStringFromIndex returns the string value for a menu index. If the index value is invalid NULL is returned. dbGetMenuIndexFromString returns the index for the given string. If the string is not a valid choice -1 is returned.
14.10.4 Locate Menu
dbMenu *dbFindMenu(DBBASE *pdbbase,char *name);
dbFindMenu is most useful for runtime use but is a static database access routine. This routine just finds a menu with the given name.
14.11 Manipulating Link Fields
14.11.1 Link Types
Links are the most complicated types of fields. A link can be a constant, reference a field in another record, or can refer to a hardware device. Two additional complications arise for hardware links. The first is that field DTYP, which is a menu field, determines if the INP or OUT field is a device link. The second is that the information that must be specified for a device link is bus dependent. In order to shelter database configuration tools from these complications the following is done for static database access.
Each link is one of the following types:
Database configuration tools can change any link between being a constant and a process variable link. Routines are provided to accomplish these tasks.
The routines dbGetString, dbPutString, and dbVerify can be used for link fields but the form routines can be used to provide a friendlier user interface.
14.11.2 All Link Fields
int  dbGetNLinks(DBENTRY *pdbentry);
long dbGetLinkField(DBENTRY *pdbentry,int index)
int  dbGetLinkType(DBENTRY *pdbentry);
These are routines for manipulating DCT_xxxLINK fields. dbGetNLinks and dbGetLinkField are used to walk through all the link fields of a record. dbGetLinkType returns one of the values: DCT_LINK_CONSTANT, DCT_LINK_PV, DCT_LINK_FORM, or the value -1 if it is called for an illegal field.
14.11.3 Constant and Process Variable Links
long dbCvtLinkToConstant(DBENTRY *pdbentry);
long dbCvtLinkToPvlink(DBENTRY *pdbentry);
These routines should be used for modifying DCT_LINK_CONSTANT or DCT_LINK_PV links. They should not be used for DCT_LINK_FORM links, which should be processed via the associated DCT_MENUFORM field described above.
14.11.4 Get Related Field
char *dbGetRelatedField(DBENTRY *pdbentry)
This routine returns the field name of the related field for a DCT_MENUFORM field. If it is called for any other type of field it returns NULL.
14.12 Manipulating Information Items
Information items are stored as a list attached to each individual record instance. All routines listed in this section require that the DBENTRY argument refer to a valid record instance.
14.12.1 Locate Item
long dbFirstInfo(DBENTRY *pdbentry);
long dbNextInfo(DBENTRY *pdbentry);
long dbFindInfo(DBENTRY *pdbentry,const char *name);
There are two ways to locate info items, by scanning through the list using first/next, or by asking for the item by name. These routines set pdbentry to refer to the info item and return 0, or return an error code if no info item is found.
14.12.2 Get Item Name
const char * dbGetInfoName(DBENTRY *pdbentry);
Returns the name of the info item referred to by pdbentry, or a NULL pointer if no item is referred to.
14.12.3 Get/Set Item String Value
const char * dbGetInfoString(DBENTRY *pdbentry);
long dbPutInfoString(DBENTRY *pdbentry,const char *string);
These routines provide access to the currently selected item's string value. When changing the string value using dbPutInfoSting, the character string provided will be copied, with additional memory being allocated as necessary. Developers are advised not to make continuously repeated calls to dbPutInfoString at IOC runtime as this could fragment the free memory heap. The Put routine returns 0 if Ok or an error code; the Get routine returns NULL on error.
14.12.4 Get/Set Item Pointer Value
void * dbGetInfoPointer(DBENTRY *pdbentry);
long dbPutInfoPointer(DBENTRY *pdbentry, void *pointer);
Each info item includes space to store a single void* pointer as well as the value string. Applications using the info item may set this as often as they wish. The Put routine returns 0 if Ok or an error code; the Get routine returns NULL on error.
14.12.5 Create/Delete Item
long dbPutInfo(DBENTRY *pdbentry,const char *name,const char *string);
long dbDeleteInfo(DBENTRY *pdbentry);
A new info item can be created by calling dbPutInfo. If an item by that name already exists its value will be replaced with the new string, otherwise storage is allocated and the name and value strings copied into it. The function returns 0 on success, or an error code.
When calling dbDeleteInfo, pdbentry must refer to the item to be removed (using dbFirstInfo, dbNextInfo or dbFindInfo). The function returns 0 on success, or an error code.
14.12.6 Convenience Routine
const char * dbGetInfo(DBENTRY *pdbentry,const char *name);
It is common to want to look up the value of a named info item in one call, and dbGetInfo is provided for this purpose. It returns a NULL pointer if no info item exists with the given name.
14.13 Find Breakpoint Table
brkTable *dbFindBrkTable(DBBASE *pdbbase,char *name)
This routine returns the address of the specified breakpoint table. It is normally used by the runtime breakpoint conversion routines so will not be discussed further.
14.14 Dump Routines
void dbDumpPath(DBBASE *pdbbase)
void dbDumpRecord(DBBASE *pdbbase,char *precordTypeName,int level);
void dbDumpMenu(DBBASE *pdbbase,char *menuName);
void dbDumpRecordType(DBBASE *pdbbase,char *recordTypeName);
void dbDumpField(DBBASE *pdbbase,char *recordTypeName,char *fname);
void dbDumpDevice(DBBASE *pdbbase,char *recordTypeName);
void dbDumpDriver(DBBASE *pdbbase);
void dbDumpRegistrar(DBBASE *pdbbase);
void dbDumpFunction(DBBASE *pdbbase);
void dbDumpVariable(DBBASE *pdbbase);
void dbDumpBreaktable(DBBASE *pdbbase,char *name);
void dbPvdDump(DBBASE *pdbbase,int verbose);
void dbReportDeviceConfig(DBBASE *pdbbase,FILE *report);
These routines are used to dump information about the database. The routines dbDumpRecord, dbDumpMenu, dbDumpDriver, dbDumpRegistrar and dbDumpVariable just call their corresponding dbWriteXxxFP routine, specifying stdout for the file to write to. dbDumpRecordType, dbDumpField, and dbDumpDevice give internal information useful on an ioc. These commands can be executed via iocsh, specifying pdbbase as the first argument.
14.15 Examples
14.15.1 Expand Include
This example is like the dbExpand utility, except that it doesn't allow path or macro substitution options. It reads a set of database definition files and writes all definitions to stdout. All include statements appearing in the input files are expanded.
/* dbExpand.c */
#include <stdlib.h>
#include <stddef.h>
#include <stdio.h>
#include <epicsPrint.h>
#include <dbStaticLib.h>
DBBASE *pdbbase = NULL;
int main(int argc,char **argv)
    longstatus;
    inti;
    intarg;
    if(argc<2) {
        printf("usage: expandInclude file1.db file2.db...\n");
        exit(0);
    for(i=1; i<argc; i++) {
        status = dbReadDatabase(&pdbbase,argv[i],NULL,NULL);
        if(!status) continue;
        fprintf(stderr,"For input file %s",argv[i]);
        errMessage(status,"from dbReadDatabase");
    dbWriteMenuFP(pdbbase,stdout,0);
    dbWriteRecordTypeFP(pdbbase,stdout,0);
    dbWriteDeviceFP(pdbbase.stdout);
    dbWriteDriverFP(pdbbase.stdout);
    dbWriteRecordFP(pdbbase,stdout,0,0);
    return(0);
14.15.2 dbDumpRecords
NOTE: This example is similar but not identical to the actual dbDumpRecords routine.
The following example demonstrates how to use the database access routines. The example shows how to locate each record and display each field.
void dbDumpRecords(DBBASE *pdbbase)
    DBENTRY  *pdbentry;
    long  status;
    pdbentry = dbAllocEntry(pdbbase);
    if(status) {printf("No record descriptions\n");return;}
    while(!status) {
        printf("record type: %s",dbGetRecordTypeName(pdbentry));
        status = dbFirstRecord(pdbentry);
        if(status) printf("  No Records\n");
        while(!status) {
            if (dbIsAlias(pdbentry)
                printf("\n  Alias:%s\n",dbGetRecordName(pdbentry));
            else {
                printf("\n  Record:%s\n",dbGetRecordName(pdbentry));
                status = dbFirstField(pdbentry,TRUE);
                    if(status) printf("    No Fields\n");
                while(!status) {
                    printf("    %s: %s",dbGetFieldName(pdbentry),
                        dbGetString(pdbentry));
                    status=dbNextField(pdbentry,TRUE);
            status = dbNextRecord(pdbentry);
        status = dbNextRecordType(pdbentry);
    printf("End of all Records\n");
    dbFreeEntry(pdbentry);
Andrew Johnson 2016-02-09
