next up previous contents index
Next: 10. IOC Error Logging Up: AppDevGuide Previous: 8. Access Security   Contents   Index
Subsections
9. IOC Test Facilities
9.1 Overview
This chapter describes a number of IOC test routines that are of interest to both application developers and system developers. The routines are available from either iocsh or the vxWorks shell. In both shells the parentheses around arguments are optional. On vxWorks all character string arguments must be enclosed in double quote characters "" and all arguments must be separated by commas. For iocsh single or double quotes must be used around string arguments that contain spaces or commas but are otherwise optional, and arguments may be separated by either commas or spaces. For example:
dbpf("aiTest","2")
dbpf "aiTest","2"
are both valid with both iocsh and with the vxWorks shell.
dbpf aiTest 2
Is valid for iocsh but not for the vxWorks shell.
Both iosch and vxWorks shells allow output redirection, i.e. the standard output of any command can be redirected to a file. For example
dbl > dbl.lst
will send the output of the dbl command to the file dbl.lst
If iocsh is being used it provides help for all commands that have been registered. Just type
help
or
help pattern*
9.2 Database List, Get, Put
9.2.1 dbl
Database List:
dbl("<record type>","<field list>")
Examples
dbl
dbl("ai")
dbl("*")
dbl("")
This command prints the names of records in the run time database. If <record type> is empty (""), "*", or not specified, all records are listed. If <record type> is specified, then only the names of the records of that type are listed.
If <field list> is given and not empty then the values of the fields specified are also printed.
9.2.2 dbgrep
List Record Names That Match a Pattern:
dbgrep("<pattern>")
Examples
dbgrep("S0*")
dbgrep("*gpibAi*")
Lists all record names that match a pattern. The pattern can contain any characters that are legal in record names as well as "*", which matches 0 or more characters.
9.2.3 dbla
List Record Alias Names with optional pattern:
dbla
dbla("<pattern>")
Lists the names of all aliases (which match the pattern if given) and the records they refer to. Examples:
dbla
dbla "alia*"
9.2.4 dba
Database Address:
dba("<record_name.field_name>")
Example
dba("aitest")
dba("aitest.VAL")
This command calls dbNameToAddr and then prints the value of each field in the dbAddr structure describing the field. If the field name is not specified then VAL is assumed (the two examples above are equivalent).
9.2.5 dbgf
Get Field:
dbgf("<record_name.field_name>")
Example:
dbgf("aitest")
dbgf)"aitest.VAL")
This performs a dbNameToAddr and then a dbGetField. It prints the field type and value. If the field name is not specified then VAL is assumed (the two examples above are equivalent). Note that dbGetField locks the record lockset, so dbgf will not work on a record with a stuck lockset; use dbpr instead in this case.
9.2.6 dbpf
Put Field:
dbpf("<record_name.field_name>","<value>")
Example:
dbpf("aitest","5.0")
This command performs a dbNameToAddr followed by a dbPutField and dbgf. If <field_name> is not specified VAL is assumed.
9.2.7 dbpr
Print Record:
dbpr("<record_name>",<interest level>)
Example
dbpr("aitest",2)
This command prints all fields of the specified record up to and including those with the indicated interest level. Interest level has one of the following values:
9.2.8 dbtr
Test Record:
dbtr("<record_name>")
This calls dbNameToAddr, then dbProcess and finally dbpr (interest level 3). Its purpose is to test record processing.
9.2.9 dbnr
Print number of records:
dbnr(<all_recordtypes>)
This command displays the number of records of each type and the total number of records. If all_record_types is 0 then only record types with record instances are displayed otherwise all record types are displayed.
9.3 Breakpoints
A breakpoint facility that allows the user to step through database processing on a per lockset basis. This facility has been constructed in such a way that the execution of all locksets other than ones with breakpoints will not be interrupted. This was done by executing the records in the context of a separate task.
The breakpoint facility records all attempts to process records in a lockset containing breakpoints. A record that is processed through external means, e.g.: a scan task, is called an entrypoint into that lockset. The dbstat command described below will list all detected entrypoints to a lockset, and at what rate they have been detected.
9.3.1 dbb
Set Breakpoint:
dbb("<record_name>")
Sets a breakpoint in a record. Automatically spawns the bkptCont, or breakpoint continuation task (one per lockset). Further record execution in this lockset is run within this task's context. This task will automatically quit if two conditions are met, all breakpoints have been removed from records within the lockset, and all breakpoints within the lockset have been continued.
9.3.2 dbd
Remove Breakpoint:
dbd("<record_name>")
Removes a breakpoint from a record.
9.3.3 dbs
Single Step:
dbs("<record_name>")
Steps through execution of records within a lockset. If this command is called without an argument, it will automatically step starting with the last detected breakpoint.
9.3.4 dbc
Continue:
dbc("<record_name>")
Continues execution until another breakpoint is found. This command may also be called without an argument.
9.3.5 dbp
Print Fields Of Suspended Record:
dbp("<record_name>,<interest_level>)
Prints out the fields of the last record whose execution was suspended.
9.3.6 dbap
Auto Print:
dbap("<record_name>")
Toggles the automatic record printing feature. If this feature is enabled for a given record, it will automatically be printed after the record is processed.
9.3.7 dbstat
Status:
dbstat
Prints out the status of all locksets that are suspended or contain breakpoints. This lists all the records with breakpoints set, what records have the autoprint feature set (by dbap), and what entrypoints have been detected. It also displays the vxWorks task ID of the breakpoint continuation task for the lockset. Here is an example output from this call:
LSet: 00009  Stopped at: so#B: 00001   T: 0x23cafac
             Entrypoint: so#C: 00001   C/S:     0.1
             Breakpoint: so(ap)
LSet: 00008#B: 00001   T: 0x22fee4c
             Breakpoint: output
The above indicates that two locksets contain breakpoints. One lockset is stopped at record ``so." The other is not currently stopped, but contains a breakpoint at record ``output." ``LSet:" is the lockset number that is being considered. "#B:" is the number of breakpoints set in records within that lockset. ``T:" is the vxWorks task ID of the continuation task. ``C:" is the total number of calls to the entrypoint that have been detected. ``C/S:" is the number of those calls that have been detected per second. (ap) indicates that the autoprint feature has been turned on for record ``so."
9.4 Trace Processing
The user should also be aware of the field TPRO, which is present in every database record. If it is set TRUE then a message is printed each time its record is processed and a message is printed for each record processed as a result of it being processed.
9.5 Error Logging
9.5.1 eltc
Display error log messages on console:
eltc(int noYes)
This determines if error messages are displayed on the IOC console. 0 means no and any other value means yes.
9.5.2 errlogInit, errlogInit2
Initialize error log client buffering
errlogInit(int bufSize)
errlogInit2(int bufSize, int maxMsgSize)
The error log client maintains a circular buffer of messages that are waiting to be sent to the log server. If not set using one or other of these routines the default value for bufSize is 1280 bytes and for maxMsgSize is 256 bytes.
9.5.3 errlog
Send a message to the log server
errlog("<message>")
This command is provided for use from the ioc shell only. It sends its string argument and a new-line to the log server, without displaying it on the IOC console. Note that the iocsh will have expanded any environment variable macros in the string (if it was double-quoted) before passing it to errlog.
9.6 Hardware Reports
9.6.1 dbior
I/O Report:
dbior ("<driver_name>",<interest level>)
This command calls the report entry of the indicated driver. If <driver_name> is ``" or ``*", then a report for all drivers is generated. The command also calls the report entry of all device support modules. Interest level is one of the following:
9.6.2 dbhcr
Hardware Configuration Report:
dbhcr()
This command produces a report of all hardware links. To use it on the IOC, issue the command:
dbhcr > report
The report will probably not be in the sort order desired. The Unix command:
sort report > report.sort
should produce the sort order you desire.
9.7 Scan Reports
9.7.1 scanppl
Print Periodic Lists:
scanppl(double rate)
This routine prints a list of all records in the periodic scan list of the specified rate. If rate is 0.0 all period lists are shown.
9.7.2 scanpel
Print Event Lists:
scanpel(int event_number)
This routine prints a list of all records in the event scan list for the specified event nunber. If event_number is 0 all event scan lists are shown.
9.7.3 scanpiol
Print I/O Event Lists:
scanpiol
This routine prints a list of all records in the I/O event scan lists.
9.8 General Time
The built-in time providers depend on the IOC's target architecture, so some of the specific subsystem report commands listed below are only available on the architectures that use that particular provider.
9.8.1 generalTimeReport
Format:
generalTimeReport(int level)
This routine displays the time providers and their priority levels that have registered with the General Time subsystem for both current and event times. At level 1 it also shows the current time as obtained from each provider.
9.8.2 installLastResortEventProvider
Format:
Installs the optional Last Resort event provider at priority 999, which returns the current time for every event number.
9.8.3 NTPTime_Report
Format:
NTPTime_Report(int level)
Only vxWorks and RTEMS targets use this time provider. The report displays the provider's synchronization state, and at interest level 1 it also gives the synchronization interval, when it last synchronized, the nominal and measured system tick rates, and on vxWorks the NTP server address.
9.8.4 NTPTime_Shutdown
Format:
NTPTime_Shutdown
On vxWorks and RTEMS this command shuts down the NTP time synchronization thread. With the thread shut down, the driver will no longer act as a current time provider.
9.8.5 ClockTime_Report
Format:
ClockTime_Report(int level)
This time provider is used on several target architectures, registered as the time provider of last resort. On vxWorks and RTEMS the report displays the synchronization state, when it last synchronized the system time with a higher priority provider, and the synchronization interval. On workstation operating systems the synchronization task is not started on the assumption that some other process is taking care of synchronzing the OS clock as appropriate, so the report is minimal.
9.8.6 ClockTime_Shutdown
Format:
ClockTime_Shutdown
Some sites may prefer to provide their own implementation of a system clock time provider to replace the built-in one. On vxWorks and RTEMS this command stops the OS Clock synchronization thread, allowing the OS clock to free-run. The time provider will continue to return the current system time after this command is used however.
9.9 Access Security Commands
9.9.1 asSetSubstitutions
Format:
asSetSubstitutions("substitutions")
Specifies macro substitutions used when access security is initialized.
9.9.2 asSetFilename
Format:
asSetFilename("<filename>")
This command defines a new access security file.
9.9.3 asInit
Format:
asInit
This command reinitializes the access security system. It rereads the access security file in order to create the new access security database. This command is useful either because the asSetFilename command was used to change the file or because the file itself was modified. Note that it is also possible to reinitialize the access security via a subroutine record. See the access security document for details.
9.9.4 asdbdump
Format:
asdbdump
This provides a complete dump of the access security database.
9.9.5 aspuag
Format:
aspuag("<user access group>")
Print the members of the user access group. If no user access group is specified then the members of all user access groups are displayed.
9.9.6 asphag
Format:
asphag("<host access group>")
Print the members of the host access group. If no host access group is specified then the members of all host access groups are displayed.
9.9.7 asprules
Format:
asprules("<access security group>")
Print the rules for the specified access security group or if no group is specified for all groups.
9.9.8 aspmem
Format:
aspmem("<access security group>", <print clients>)
Print the members (records) that belong to the specified access security group, for all groups if no group is specified. If <print clients> is (0, 1) then Channel Access clients attached to each member (are not, are) shown.
9.10 Channel Access Reports
9.10.1 casr
Channel Access Server Report
casr(<level>)
Level can have one of the following values:
0
Prints server's protocol version level and a one line summary for each client attached. The summary lines contain the client's login name, client's host name, client's protocol version number, and the number of channel created within the server by the client.
1
Level one provides all information in level 0 and adds the task id used by the server for each client, the client's IP protocol type, the file number used by the server for the client, the number of seconds elapsed since the last request was received from the client, the number of seconds elapsed since the last response was sent to the client, the number of unprocessed request bytes from the client, the number of response bytes which have not been flushed to the client, the client's IP address, the client's port number, and the client's state.
2
Level two provides all information in levels 0 and 1 and adds the number of bytes allocated by each client and a list of channel names used by each client. Level 2 also provides information about the number of bytes in the server's free memory pool, the distribution of entries in the server's resource hash table, and the list of IP addresses to which the server is sending beacons. The channel names are shown in the form:
<name>(nrw)
where
n is number of ca_add_events the client has on this channel
r is (-,R) if client (does not, does) have read access to the channel.
w is(-, W) if client (does not, does) have write access to the channel.
9.10.2 dbel
Format:
dbel("<record_name>")
This routine prints the Channel Access event list for the specified record.
9.10.3 dbcar
Database to Channel Access Report - See ``Record Link Reports"
9.10.4 ascar
Format:
ascar(level)
Prints a report of the channel access links for the INP fields of the access security rules. Level 0 produces a summary report. Level 1 produces a summary report plus details on any unconnect channels. Level 2 produces the summary nreport plus a detail report on each channel.
9.11 Interrupt Vectors
9.11.1 veclist
Format:
veclist
NOTE: This routine is only available on vxWorks. On PowerPC CPUs it requires BSP support to work, and even then it cannot display chained interrupts using the same vector.
Print Interrupt Vector List
9.12 Miscellaneous
9.12.1 epicsParamShow
Format:
epicsParamShow
or
epicsPrtEnvParams
Print the environment variables that are created with epicsEnvSet. These are defined in <base>/config/CONFIG_ENV and <base>/config/CONFIG_SITE_ENV or else by user applications calling epicsEnvSet.
9.12.2 epicsEnvShow
Format:
epicsEnvShow("<name>")
Show Environment variables. On vxWorks it shows the variables created via calls to putenv.
9.12.3 coreRelease
Format:
coreRelease
Print release information for iocCore.
9.13 Database System Test Routines
These routines are normally only of interest to EPICS system developers NOT to Application Developers.
9.13.1 dbtgf
Test Get Field:
dbtgf("<record_name.field_name>")
Example:
dbtgf("aitest")
dbtgf)"aitest.VAL")
This performs a dbNameToAddr and then calls dbGetField with all possible request types and options. It prints the results of each call. This routine is of most interest to system developers for testing database access.
9.13.2 dbtpf
Test Put Field:
dbtpf("<record_name.field_name>","<value>")
Example:
dbtpf("aitest","5.0")
This command performs a dbNameToAddr, then calls dbPutField, followed by dbgf for each possible request type. This routine is of interest to system developers for testing database access.
9.13.3 dbtpn
Test Process Notify:
dbtpn("<record_name.field_name>")
dbtpn("<record_name.field_name>","<value>")
Example:
dbtpn("aitest")
dbtpn("aitest","5.0")
This command performs a dbProcessNotify request. If a non-null value argument string is provided it issues a putProcessRequest to the named record; if no value is provided it issues a processGetRequest. This routine is mainly of interest to system developers for testing database access.
9.14 Record Link Reports
9.14.1 dblsr
Lock Set Report:
dblsr(<recordname>,<level>)
This command generates a report showing the lock set to which each record belongs. If recordname is 0, "", or "*" all records are shown, otherwise only records in the same lock set as recordname are shown.
level can have the following values:
0- Show lock set information only.
1- Show each record in the lock set.
2- Show each record and all database links in the lock set.
9.14.2 dbLockShowLocked
Show locked locksets:
dbLockShowLocked(<level>)
This command generates a report showing all locked locksets, the records they contain, the lockset state and the thread that currently owns the lockset. The level argument is passed to epicsMutexShow to adjust the information reported about each locked epicsMutex.
9.14.3 dbcar
Database to channel access report
dbcar(<recordname>,<level>)
This command generates a report showing database channel access links. If recordname is ``*" then information about all records is shown otherwise only information about the specified record.
0- Show summary information only.
1- Show summary and each CA link that is not connected.
2- Show summary and status of each CA link.
9.14.4 dbhcr
Report hardware links. See ``Hardware Reports".
9.15 Old Database Access Testing
These routines are of interest to EPICS system developers. They are used to test the old database access interface, which is still used by Channel Access.
9.15.1 gft
Get Field Test:
gft("<record_name.field_name>")
Example:
gft("aitest")
gft("aitest.VAL")
This performs a db_name_to_addr and then calls db_get_field with all possible request types. It prints the results of each call. This routine is of interest to system developers for testing database access.
9.15.2 pft
Put Field Test:
pft("<record_name.field_name>","<value>")
Example:
pft("aitest","5.0")
This command performs a db_name_to_addr, db_put_field, db_get_field and prints the result for each possible request type. This routine is of interest to system developers for testing database access.
9.15.3 tpn
Example:
tpn("aitest","5.0")
This routine tests the dbProcessNotify API when used via the old database access interface. It only supports issuing a putProcessRequest to the named record.
9.16 Routines to dump database information
9.16.1 dbDumpPath
Dump Path:
dbDumpPath(pdbbase)
   dbDumpPath(pdbbase)
The current path for database includes is displayed.
9.16.2 dbDumpMenu
Dump Menu:
dbDumpMenu(pdbbase,"<menu>")
   dbDumpMenu(pdbbase,"menuScan")
If the second argument is 0 then all menus are displayed.
9.16.3 dbDumpRecordType
Dump Record Description:
dbDumpRecordType(pdbbase,"<record type>")
   dbDumpRecordType(pdbbase,"ai")
If the second argument is 0 then all descriptions of all records are displayed.
9.16.4 dbDumpField
Dump Field Description:
dbDumpField(pdbbase,"<record type>","<field name>")
   dbDumpField(pdbbase,"ai","VAL")
If the second argument is 0 then the field descriptions of all records are displayed. If the third argument is 0 then the description of all fields are displayed.
9.16.5 dbDumpDevice
Dump Device Support:
dbDumpDevice(pdbbase,"<record type>")
   dbDumpDevice(pdbbase,"ai")
If the second argument is 0 then the device support for all record types is displayed.
9.16.6 dbDumpDriver
Dump Driver Support:
dbDumpDriver(pdbbase)
9.16.7 dbDumpRecord
Dump Record Instances:
dbDumpRecord(pdbbase,"<record type>",level)
   dbDumpRecords(pdbbase,"ai")
If the second argument is 0 then the record instances for all record types are displayed. The third argument determines which fields are displayed just like for the command dbpr.
9.16.8 dbDumpBreaktable
Dump breakpoint table
dbDumpBreaktable(pdbbase,name)
   dbDumpBreaktable(pdbbase,"typeKdegF")
This command dumps a breakpoint table. If the second argument is 0 all breakpoint tables are dumped.
9.16.9 dbPvdDump
Dump the Process variable Directory:
dbPvdDump(pdbbase,verbose)
   dbPvdDump(pdbbase,0)
This command shows how many records are mapped to each hash table entry of the process variable directory. If verbose is not 0 then the command also displays the names which hash to each hash table entry.
Andrew Johnson 2015-04-14
