next up previous contents index
Next: Index Up: AppDevGuide Previous: 21. Registry   Contents   Index
Subsections
22. Database Structures
22.1 Overview
This chapter describes the internal structures describing an IOC database. It is of interest to EPICS system developers but serious application developers may also find it useful. This chapter is intended to make it easier to understand the IOC source listings. It also gives a list of the header files used by IOC Code.
22.2 Include Files
This section lists the files in base/include that are of most interest to IOC Application Developers:
alarm.h alarmString.h
- These files contain definitions for all alarm status and severity values.
cadef.h caerr.h caeventmask.h
- These files are of interest to anyone writing channel access clients.
callback.h
- The definitions for the General Purpose callback system.
dbAccess.h
- Definitions for the runtime database access routines.
dbBase.h
- Definitions for the structures used to store an EPICS database.
dbDefs.h
- A catchall file for definitions that have no other reasonable place to appear.
dbFldTypes.h
- Definitions for DBF_xxx and DBR_xxx types.
dbScan.h
- Definitions for the scanning system.
dbStaticLib.h
- The static databases access system.
db_access.h db_addr.h
- Old database access.
devLib.h
- The device support library
devSup.h
- Device Support Modules
drvSup.h
- Driver Support Modules
ellLib.h
- A library that is provides the same functions as the vxWorks lstLib. All routines start with ell instead of lst. The ellLib routines work on all architectures.
epicsPrint.h errMdef.h
- EPICS error handling system
fast_lock.h
- The FASTLOCK routines.
freeList.h
- A general purpose free list facility
gpHash.h
- A general purpose hash library.
guigroup.h
- The guigroup definitions.
initHooks.h
- Definitions used by initHooks.c routines.
link.h
- Link definitions
module_types.h
- VME hardware configuration. SHOULD NOT BE USED BY NEW SUPPORT.
recSup.h
- The record global routines.
special.h
- Definitions for special fields, i.e. SPC_xxx.
task_params.h
- Definitions for task priorities, stack space, etc.
taskwd.h
- Task Watchdog System
tsDefs.h
- Time stamp routines. Will also have to look at base/src/libCom/tsSubr.c
22.3 Structures
\includegraphics{databaseStructures_1}
Andrew Johnson 2012-12-17
