Most code in base is operating system independent, i.e. the code is exactly the same for all supported operating systems. This is accomplished by providing epics defined libraries for facilities that are different on the various systems. The code is called Operating System Independent or OSI. OSI libraries have multiple implementations, which are Operating System Dependent or OSD.
Directory <base>/src/libCom/osi contains the code for the operating system independent libraries. The structure
of this directory is:
osi/
epics*.h
*.cpp - A few generic c++ implementations
os/
Linux/
Darwin/
RTEMS/
WIN32/
default/
posix/
solaris/
vxWorks/
Code for additional operating systems may also be present.
The osi directory contains header files with names starting with epics. These headers provide definitions for user code.
Each of the directories under osi/<arch> contain architecture-specific code in filenames starting with osd. In most
cases both a header and source file are present.
Installing header files residing under src/libCom/osi into <base>/include
osi are installed into <base>/include
osi/os are installed into <base>/include/os/<arch>.The search
order for locating the specific file to be installed is:
libCom/osi/os/<arch>
libCom/osi/os/posix
libCom/osi/os/default
The search order for locating osd source files is:
libCom/osi/os/posix
When code is compiled the search order for locating header files in base/include is:
<base>/include
This is a replacement for ANSI C's assert. To use this version just include:
#include "epicsAssert.h"
instead of
#include <assert.h>
If an assert fails, it calls errlog indicating the program's author, file name, and line number. Under each OS there are
specialized instructions assisting the user to diagnose the problem and generate a good bug report. For instance, under
vxWorks, there are instructions on how to generate a stack trace, and on posix there are instructions about saving the core
file. After printing the message the calling thread is suspended.
An author may, before the above include line, optionally define a preprocessor macro named epicsAssertAuthor as
a string that provides their name and email address if they wish to be contacted when the assertion fires.
epicsEndian.h provides an operating-system independent means of discovering the native byte order of the CPU
which the compiler is targeting, and works for both C and C++ code. It defines the following preprocessor macros, the
values of which are integers:
The latter two macros are defined to be one or other of the first two and may be compared with them to determine conditional compilation or execution of code that performs byte or word swapping as necessary.
epicsEvent.h contains a C++ and a C description for an event semaphore.
typedef enum {
epicsEventWaitOK,epicsEventWaitTimeout,epicsEventWaitError
}epicsEventWaitStatus;
typedef enum {epicsEventEmpty,epicsEventFull} epicsEventInitialState;
class epicsEvent{
public:
epicsEvent(epicsEventInitialState initial=epicsEventEmpty);
~epicsEvent();
void signal();
void wait(); /*blocks until full*/
bool wait( double timeOut ); /* false if empty at time out */
bool tryWait(); /* false if empty */
void show( unsigned level ) const;
class invalidSemaphore {}; /* exception */
private:
| Method | Meaning |
| epicsEvent | An epicsEvent can be created empty or full. If it is created empty then a wait issued before a signal will block. If created full then the first wait will always succeed. Multiple signals may be issued between waits but have the same effect as a single signal. |
| ~epicsEvent | Remove the event and any resources it uses. Any further use of the semaphore result in unknown (most certainly bad) behavior. No outstanding take can be active when this call is made. |
| signal | Signal the event i.e. ensures that the next or current call to wait completes. This method may be called from a vxWorks or RTEMS interrupt handler. |
| wait() | Wait for the event. |
| wait(double timeOut) | Similar to wait except that if event does not happen the call completes after the specified time out. The return value is (false,true) if the event (did not, did) happen. |
| tryWait() | Similar to wait except that if event does not happen the call completes immediately. The return value is (false,true) if the event (did not, did) happen. |
| show | Display information about the semaphore. The information displayed is architecture dependent. |
The primary use of an event semaphore is for synchronization. An example of using an event semaphore is a consumer thread that processes requests from one or more producer threads. For example:
epicsEvent *pevent = new epicsEvent;
while(1) {
pevent->wait();
while(/*more work*/) {
/*process work*/
pevent->signal();
typedef struct epicsEventOSD *epicsEventId; epicsEventId epicsEventCreate(epicsEventInitialState initialState); epicsEventId epicsEventMustCreate (epicsEventInitialState initialState); void epicsEventDestroy(epicsEventId id); void epicsEventSignal(epicsEventId id); epicsEventWaitStatus epicsEventWait(epicsEventId id); void epicsEventMustWait(epicsEventId id); epicsEventWaitStatus epicsEventWaitWithTimeout(epicsEventId id, double timeOut); epicsEventWaitStatus epicsEventTryWait(epicsEventId id); void epicsEventShow(epicsEventId id, unsigned int level);
Each C routine corresponds to one of the C++ methods. epicsEventMustCreate and epicsEventMustWait do
not return if they fail.
epicsFindSymbol.h contains the following definition:
void * epicsFindSymbol(const char *name);
| Method | Meaning |
| epicsFindSymbol | Return the address of the variable name |
vxWorks provides a function symFindByName, which finds and returns the address of global variables. The registry, described in the next chapter, provides an alternative but also requires extra work by iocCore and/or user code. If the registry is asked for a name that has not been registered, it calls epicsFindSymbol. If epicsFindSymbol can locate the global symbol it returns the address, otherwise it returns null.
On vxWorks epicsFindSymbol calls symFindByName.
A default version just returns null, i.e. it always fails.
The generalTime framework provides a mechanism for several time providers to be present within the system. There are two types of provider, one type for the current time and one type for providing Time Event times. Each time provider has a priority, and installed providers are queried in priority order whenever a time is requested, until one returns successfully. Thus there is a fallback from higher priority providers (smaller value of priority) to lower priority providers (larger value of priority) if the higher priority ones fail. Each architecture has a ``last resort" provider, installed at priority 999, usually based on the system clock, which is used in the absence of any other provider.
Targets running vxWorks and RTEMS have an NTP provider installed at priority 100.
Registered providers may also add an interrupt-safe routine that will be called from the epicsTimeGetCurrentInt() or epicsTimeGetEventInt() API routines. These interfaces do not check the priority queue, and will only succeed if the last- used provider has registered a suitable routine.
There are two interfaces to this framework, epicsGeneralTime.h for consumers that wish to get a time and query the framework, and generalTimeSup.h for providers that supply timestamps.
The epicsGeneralTime.h header contains the following:
void generalTime_Init(void); int installLastResortEventProvider(void); void generalTimeResetErrorCounts(); int generalTimeGetErrorCounts(); const char * generalTimeHighestCurrentName(void); const char * generalTimeCurrentProviderName(void); const char * generalTimeEventProviderName(void); /* Original names, for compatibility */ #define generalTimeCurrentTpName generalTimeCurrentProviderName #define generalTimeEventTpName generalTimeEventProviderName long generalTimeReport(int interest);
| Method | Meaning |
| generalTime_Init | Initialise the framework.This is called automatically by any function that requires the framework. It does not need to be called explicitly. |
| installLastResortEventProvider | Install a Time Event time provider that returns the current time for any Time Event number.This is optional as it is site policy whether the last resort for a Time Event time in the absence of any working provider should be a failure, or the current time. |
| generalTimeResetErrorCounts | Reset the internal counter of the number of times the time returned was earlier than when previously requested. Used by device support for bo record with DTYP = ``General Time" OUT = ``@RSTERRCNT" |
| generalTimeGetErrorCounts | Return the internal counter of the number of times the time returned was earlier than when previously requested. Used by device support for longin record with DTYP = ``General Time" INP = ``@GETERRCNT" |
| generalTimeCurrentProviderName | Return the name of the provider that last returned a valid current time, or NULL if none. Used by stringin device support with DTYP = ``General Time" INP = ``@BESTTCP" |
| generalTimeEventProviderName | Return the name of the provider that last returned a valid Time Event time, or NULL if none. Used by stringin device support with DTYP = ``General Time" INP = ``@BESTTEP" |
| generalTimeHighestCurrentName | Return the name of the registered current time provider that has the highest priority. Used by stringin device support with DTYP = ``General Time" INP = ``@TOPTCP" |
| generalTimeReport | Provide information about the installed providers and their current best times. |
The generalTimeSup.h header for time providers contains the following:
typedef int (*TIMECURRENTFUN)(epicsTimeStamp *pDest);
typedef int (*TIMEEVENTFUN)(epicsTimeStamp *pDest, int event);
int generalTimeRegisterCurrentProvider(const char *name,
int priority, TIMECURRENTFUN getTime);
int generalTimeRegisterEventProvider(const char *name,
int priority, TIMEEVENTFUN getEvent);
#define generalTimeCurrentTpRegister generalTimeRegisterCurrentProvider
#define generalTimeEventTpRegister generalTimeRegisterEventProvider
int generalTimeAddIntCurrentProvider(const char *name,
int generalTimeAddIntEventProvider(const char *name,
int generalTimeGetExceptPriority(epicsTimeStamp *pDest, int *pPrio,
int ignorePrio);
| Method | Meaning |
| generalTimeRegisterCurrentProvider | Register a current time provider with the framework. The getTime routine must return epicsTimeOK if it provided a valid time, or epicsTimeERROR if it could not. |
| generalTimeRegisterEventProvider | Register a provider of Time Event times with the framework. The getEvent routine must return epicsTimeOK if it provided a valid time for the requested Time Event, or epicsTimeERROR if it could not.It is an implemetation decision by the provider whether a request for an Event that has never happened should return an error and/or a valid timestamp. |
| generalTimeAddIntCurrentProvider | Add or replace an interrupt-safe provider routine for an already-registered current time provider with the given name and priority. |
| generalTimeAddIntEventProvider | Add or replace an interrupt-safe provider routine for an already-registered event time provider with the given name and priority. |
| generalTimeGetExceptProirity | Request the current time from the framework, but exclude providers with priority ignorePrio.This allows a provider without an absolute time source to synchronise itself with other providers that do provide an absolute time. pPrio returns the priority of the provider that supplied the result, which may be higher or lower than ignorePrio. |
If multiple providers are registered at the same priority, they will be queried in the order in which they were registered until one is able to provide the time when requested.
Some providers may start a task that periodically synchronizes themselves with a higher priority provider, using generalTimeGetExceptPriority to ensure that they are themselves excluded from this time request.
Interrupt-safe providers are optional, but an IOC that needs to request the time from interrupt context must be using a current or event time source that supports the appropriate request because only the most recently successful provider will be used (the priority list is not traversed for these requests). The result returned is not protected against backwards movement.
The generalTime framework also now provides the implementations of epicsTimeGetCurrent() and epicsTimeGetEvent(). If epicsTimeGetEvent() is called with an event number of 0 (epicsTimeEventCurrentTime) then it will get the time from the best available current time provider. Thus providers do not need to provide event times if they do not implement an event system.
Soft device support is provided for ai, bo, longin and stringin records. A typical example is:
record(ai, "$(IOC):GTIM_CURTIME") {
field(DESC, "Get Time")
field(DTYP, "General Time")
field(INP, "@TIME")
record(bo, "$(IOC):GTIM_RSTERR") {
field(DESC, "Reset ErrorCounts")
field(OUT, "@RSTERRCNT")
record(longin, "$(IOC):GTIM_ERRCNT") {
field(DESC, "Get ErrorCounts")
field(INP, "@GETERRCNT")
record(stringin, "$(IOC):GTIM_BESTTCP") {
field(DESC, "Best Time-Current-Provider")
field(INP, "@BESTTCP")
record(stringin, "$(IOC):GTIM_BESTTEP") {
field(DESC, "Best Time-Event-Provider")
field(INP, "@BESTTEP")
epicsInterrupt.h contains the following:
int epicsInterruptLock(); void epicsInterruptUnlock(int key); int epicsInterruptIsInterruptContext(); void epicsInterruptContextMessage(const char *message);
| Method | Meaning |
| epicsInterruptLock | Lock interrupts and return a key to be passed to epicsInterruptUnlock To lock the following is done. int key; ... key = epicsInterruptLock(); ... epicsInterruptUnlock(key); |
| epicsInterruptUnlock | Unlock interrupts. |
| epicsInterruptIsInterruptContext | Return (true, false) if current context is interrupt context. |
| epicsInterruptContextMessage | Generate a message while interrupt context is true. |
A vxWorks specific version is provided. It maps directly to intLib calls.
An RTEMS version is provided that maps to rtems_ calls.
A default version is provided that uses a global semaphore to lock. This version is intended for operating systems in which iocCore will run as a multi threaded process. The global semaphore is thus only global within the process. This version is intended for use on all except real time operating systems.
The vxWorks implementation will most likely not work on symmetric multiprocessing systems.
The reason epicsInterrupt is needed is:
epicsMath.h includes math.h and also ensures that isnan and isinf are defined.
epicsMessageQueue.h describes a C++ and a C facility for interlocked communication between threads.
EpicsMessageQueue provides methods for sending messages between threads on a first in, first out basis. It is designed so that a message queue can be used with multiple writer and reader threads
class epicsMessageQueue {
public:
epicsMessageQueue(unsigned int capacity, unsigned int maximumMessageSize);
~epicsMessageQueue();
bool trySend(void *message, unsigned int messageSize);
bool send(void *message, unsigned int messageSize);
bool send(void *message, unsigned int messageSize, double timeout);
int tryReceive(void *message, unsigned int messageBufferSize);
int receive(void *message, unsigned int messageBufferSize);
int receive(void *message, unsigned int messageBufferSize, double timeout);
void show(int level) const;
int pending() const;
private: // Prevent compiler-generated member functions
// default constructor, copy constructor, assignment operator
epicsMessageQueue(const epicsMessageQueue &);
epicsMessageQueue& operator=(const epicsMessageQueue &);
private: // Data
An epicsMessageQueue cannot be assigned to, copy-constructed, or constructed without giving the capacity and maximumMessageSize arguments. The C++ compiler will object to some of the statements below:
epicsMessageQueue mq0(); // Error: default constructor is private epicsMessageQueue mq1(10, 20); // OK epicsMessageQueue mq2(t1); // Error: copy constructor is private epicsMessageQueue *pmq; // OK, pointer *pmq = mq1; // Error: assignment operator is private pmq = &mq1; // OK, pointer assignment and address-of
| Method | Meaning |
| epicsMessageQueue() | Constructor. The capacity is the maximum number of messages, each containing 0 to maximumMessageSize bytes, that can be stored in the message queue. |
| ~epicsMessageQueue() | Destructor. |
| trySend() | Try to send a message. Return 0 if the message was sent to a receiver or queued for future delivery. Return -1 if no more messages can be queued or if the message is larger than the queue's maximum message size.This method may be called from a vxWorks or RTEMS interrupt handler. |
| send() | Send a message. Return 0 if the message was sent to a receiver or queued for future delivery. Return -1 if the timeout, if any, was reached before the message could be sent or queued, or if the message is larger than the queue's maximum message size. |
| tryReceive() | Try to receive a message. If the message queue is non-empty, the first message on the queue is copied to the specified location and the length of the message is returned. Returns -1 if the message queue is empty. If the pending message is larger than the specified messageBufferSize it may either return -1, or truncate the message. It is most efficient if the messageBufferSize is equal to the maximumMessageSize with which the message queue was created. |
| receive() | Wait until a message is sent and store it in the specified location. The number of bytes in the message is returned. Returns -1 if a message is not received within the timeout interval. If the received message is larger than the specified messageBufferSize it may either return -1, or truncate the message. It is most efficient if the messageBufferSize is equal to the maximumMessageSize with which the message queue was created. |
| show() | Displays some information about the message queue. The level argument controls the amount of information dispalyed. |
| pending() | Returns the number of messages presently in the queue. |
typedef void *epicsMessageQueueId;
epicsMessageQueueId epicsMessageQueueCreate(unsigned int capacity,
void epicsMessageQueueDestroy(epicsMessageQueueId);
int epicsMessageQueueTrySend(epicsMessageQueueId, void *, unsigned int);
int epicsMessageQueueSend(epicsMessageQueueId, void *, unsigned int);
int epicsMessageQueueSendWithTimeout(epicsMessageQueueId, void *, unsigned int,
double);
int epicsMessageQueueTryReceive(epicsMessageQueueId, void *, unsigned int);
int epicsMessageQueueReceive(epicsMessageQueueId, void *, unsigned int);
int epicsMessageQueueReceiveWithTimeout(epicsMessageQueueId, void*,
unsigned int, double);
void epicsMessageQueueShow(epicsMessageQueueId);
int epicsMessageQueuePending(epicsMessageQueueId);
Each C function corresponds to one of the C++ methods.
epicsMutex.h contains both C++ and C descriptions for a mutual exclusion semaphore.
typedef enum {
epicsMutexLockOK,epicsMutexLockTimeout,epicsMutexLockError
} epicsMutexLockStatus;
class epicsMutex {
public:
epicsMutex ();
~epicsMutex ();
void lock (); /* blocks until success */
bool tryLock (); /* true if successful */
void unlock ();
void show ( unsigned level ) const;
private:
| Method | Meaning |
| epicsMutex | Create a mutual exclusion semaphore. |
| ~epicsMutex | Remove the semaphore and any resources it uses. Any further use of the semaphore result in unknown (most certainly bad) results. |
| lock() | Wait until the resource is free. After a successful lock additional, i.e. recursive, locks of any type can be issued but each must have an associated unlock. |
| tryLock() | Similar to lock except that, if the resource is owned by another thread, the call completes immediately. The return value is (false,true) if the resource (is not, is) owned by the caller. |
| unlock | Release the resource. If a thread issues recursive locks, there must be an unlock for each lock |
| show | Display information about the semaphore. The results are architecture dependent. |
Mutual exclusion semaphores are for situations requiring mutually exclusive access to resources. A mutual exclusion semaphore may be taken recursively, i.e. can be taken more than once by the owner thread before releasing it. Recursive takes are useful for a set of routines that call each other while working on a mutually exclusive resource.
The typical use of a mutual exclusion semaphore is:
epicsMutex *plock = new epicsMutex;
plock->lock();
/* process resource */
plock->unlock();
typedef struct epicsMutexOSD* epicsMutexId; epicsMutexId epicsMutexCreate(void); epicsMutexId epicsMutexMustCreate (void); void epicsMutexDestroy(epicsMutexId id); void epicsMutexUnlock(epicsMutexId id); epicsMutexLockStatus epicsMutexLock(epicsMutexId id); void epicsMutexMustLock(epicsMutexId id); epicsMutexLockStatus epicsMutexTryLock(epicsMutexId id); void epicsMutexShow(epicsMutexId id,unsigned int level); void epicsMutexShowAll(int onlyLocked,unsigned int level);
Each C routine corresponds to one of the C++ methods. epicsMutexMustCreate and epicsMutexMustLock do
The implementation:
A posix version is implemented via pthreads.
epicsStdlib.h includes stdlib.h and contains definitions for the following functions/macros.
double epicsStrtod(const char *str, char **endp); int epicsScanFloat(const char *str, float *dest); int epicsScanDouble(const char *str, double *dest);
epicsStrtod has the same semantics as the C99 function strtod. It is provided because some architectures have
implementations which do not accept NAN or INFINITY. On architectures which provide an acceptable version of
strtod this is implemented as a simple macro expansion.
epicsScanFloat and epicsScanDouble behave like sscanf with a "%f" and "%lf" format string, respectively.
They are provided because some architectures have implementations of scanf which do not accept NAN or INFINITY.
epicsStdio.h contains definitions for the following functions.
int epicsSnprintf(char *str, size_t size,
const char *format, ...);
int epicsVsnprintf(char *str, size_t size,
const char *format, va_list ap);
void epicsTempName(char * pNameBuf, size_t nameBufLength );
FILE * epicsShareAPI epicsTempFile ();
enum TF_RETURN {TF_OK=0, TF_ERROR=1};
enum TF_RETURN truncateFile(const char *pFileName, unsigned size );
FILE * epicsGetStdin(void);
FILE * epicsGetStdout(void);
FILE * epicsGetStderr(void);
FILE * epicsGetThreadStdin(void);
FILE * epicsGetThreadStdout(void);
FILE * epicsGetThreadStderr(void);
void epicsSetThreadStdin(FILE *);
void epicsSetThreadStdout(FILE *);
void epicsSetThreadStderr(FILE *);
int epicsStdoutPrintf(const char *pformat, ...);
epicsSnprintf and epicsVsnprintf are meant to have the same semantics as the C99 functions snprintf and
vsnprintf. They are provided because some architectures do not implement these functions, while others do not
implement the correct semantics. If you haven't heard of these C99 functions, snprintf is like sprintf except that
the size argument gives the maximum number of characters (including the trailing zero byte) that may be placed in str.
Similarly vsnprintf is a size-limited version of vsprintf. In both cases the return value is supposed to be the
number characters (not counting the terminating zero byte) that would be written to str if it was large enough to hold
them all; the output has been truncated if the return value is size or more.
On some operating systems the implementations of these functions may not always return the correct value. If the OS
implementation does not correctly return the number of characters that would have been written when the output gets
truncated, it is not worth trying to fix this as long as both return size-1 instead; the resulting string must always be
correctly terminated with a zero byte.
Operating systems such as Solaris which follow the Single Unix Specification V2,
epicsSnprintf and
epicsVsnprintf do not provide correct C99 semantics for the return value when size is given as zero. On these
systems epicsSnprintf and epicsVsnprintf may return an error (a value less than zero) if a buffer length of
zero is passed in, so callers should not use that technique.
epicsTempName and epicsTempFile can be called to get unique filenames and files.
truncateFile returns TF_OK if the file is less than size bytes or if it was successfully truncated. Returns TF_ERROR
if the file could not be truncated.
The Stdin/Stdout/Stderr routines allow these file steams to be redirected on a per thread basis, e.g. calling
epicsSetThreadStdout will affect only the thread which calls it.
epicsGetStdin, ..., epicsStdoutPrintf are not normally called by user code. Instead code that wants to
allow redirection needs only to include epicsStdioRedirect.h
Including this file cause the following names to be changed:
stdin becomes epicsGetStdin()
stdout becomes epicsGetStdout()
stderr becomes epicsGetStderr()
printf becomes epicsStdoutPrintf
This is done so that redirection can occur. A primary use of this facility is iocsh. It allows redirection of input and output. In order for it to work, all modules involved in I/O can just include this header.
epicsThread.h contains C++ and C descriptions for a thread.
typedef void (*EPICSTHREADFUNC)(void *parm);
static const unsigned epicsThreadPriorityMax = 99;
static const unsigned epicsThreadPriorityMin = 0;
/* some generic values */
static const unsigned epicsThreadPriorityLow = 10;
static const unsigned epicsThreadPriorityMedium = 50;
static const unsigned epicsThreadPriorityHigh = 90;
/* some iocCore specific values */
static const unsigned epicsThreadPriorityCAServerLow = 20;
static const unsigned epicsThreadPriorityCAServerHigh = 40;
static const unsigned epicsThreadPriorityScanLow = 60;
static const unsigned epicsThreadPriorityScanHigh = 70;
static const unsigned epicsThreadPriorityIocsh = 91;
static const unsigned epicsThreadPriorityBaseMax = 91;
/* stack sizes for each stackSizeClass are implementation and CPU dependent */
typedef enum {
epicsThreadStackSmall, epicsThreadStackMedium, epicsThreadStackBig
} epicsThreadStackSizeClass;
typedef enum {
epicsThreadBooleanStatusFail, epicsThreadBooleanStatusSuccess
} epicsThreadBooleanStatus;
unsigned int epicsThreadGetStackSize(epicsThreadStackSizeClass size);
typedef int epicsThreadOnceId;
#define EPICS_THREAD_ONCE_INIT 0
void epicsThreadOnce(epicsThreadOnceId *id, EPICSTHREADFUNC, void *arg);
void epicsThreadExitMain(void);
/* (epicsThreadId)0 is guaranteed to be an invalid thread id */
typedef struct epicsThreadOSD *epicsThreadId;
epicsThreadId epicsThreadCreate(const char *name,
unsigned int priority, unsigned int stackSize,
EPICSTHREADFUNC funptr,void *parm);
void epicsThreadSuspendSelf(void);
void epicsThreadResume(epicsThreadId id);
unsigned int epicsThreadGetPriority(epicsThreadId id);
unsigned int epicsThreadGetPrioritySelf();
void epicsThreadSetPriority(epicsThreadId id,unsigned int priority);
epicsThreadBooleanStatus epicsThreadHighestPriorityLevelBelow (
unsigned int priority, unsigned *pPriorityJustBelow);
epicsThreadBooleanStatus epicsThreadLowestPriorityLevelAbove (
unsigned int priority, unsigned *pPriorityJustAbove);
int epicsThreadIsEqual(epicsThreadId id1, epicsThreadId id2);
int epicsThreadIsSuspended(epicsThreadId id);
void epicsThreadSleep(double seconds);
double epicsThreadSleepQuantum(void);
epicsThreadId epicsThreadGetIdSelf(void);
epicsThreadId epicsThreadGetId(const char *name);
const char * epicsThreadGetNameSelf(void);
void epicsThreadGetName(epicsThreadId id, char *name, size_t size);
int epicsThreadIsOkToBlock(void);
void epicsThreadSetOkToBlock(int isOkToBlock);
void epicsThreadShowAll(unsigned int level);
void epicsThreadShow(epicsThreadId id,unsigned int level);
typedef void * epicsThreadPrivateId;
epicsThreadPrivateId epicsThreadPrivateCreate(void);
void epicsThreadPrivateDelete(epicsThreadPrivateId id);
void epicsThreadPrivateSet(epicsThreadPrivateId,void *);
void * epicsThreadPrivateGet(epicsThreadPrivateId);
| Method | Meaning |
| epicsThreadGetStackSize | Get a stack size value that can be given to epicsThreadCreate. The size argument should be one of the values epicsThreadStackSmall, epicsThreadStackMedium or epicsThreadStackBig. |
| epicsThreadOnce | This is used as follows: void myInitFunc(void * arg) { ... } epicsThreadOnceId onceFlag = EPICS_THREAD_ONCE_INIT; ... epicsThreadOnce(&onceFlag,myInitFunc,(void *)myParm);For each unique epicsThreadOnceId, epicsThreadOnce guarantees 1) myInitFunc is called only once. 2) myInitFunc completes before any epicsThreadOnce call completes.Note that myInitFunc must not call epicsThreadOnce with the same onceId. |
| epicsThreadExitMain | If the main routine is done but wants to let other threads run it can call this routine. This should be the last call in main, except the final return. On most systems epicsThreadExitMain never returns. This must only be called by the main thread. |
| epicsThreadCreate | Create a new thread. The use made of the priority, and stackSize arguments is implementation dependent. Some implementations may ignore one or other of these, but for portability appropriate values should be given for both. The value passed as the stackSize parameter should be obtained by calling epicsThreadGetStackSize. The funptr argument specifies a function that implements the thread, and parm is the single argument passed to funptr. A thread terminates when funptr returns. |
| epicsThreadSuspendSelf | This causes the calling thread to suspend. The only way it can resume is for another thread to call epicsThreadResume. |
| epicsThreadResume | Resume a suspended thread. Only do this if you know that it is safe to resume a suspended thread. |
| epicsThreadGetPriority | Get the priority of the specified thread. |
| epicsThreadGetPrioritySelf | Get the priority of this thread. |
| epicsThreadSetPriority | Set a new priority for the specified thread. The result is implementation dependent. |
| epicsThreadHighestPriorityLevelBelow | Get a priority that is just lower than the specified priority. |
| epicsThreadLowestPriorityLevelAbove | Get a priority that is just above the specified priority. |
| epicsThreadIsEqual | Compares two threadIds and returns (0,1) if they (are not, are) the same. |
| epicsThreadIsSuspended | BAD NAME. taskwd needs this call. It really means: Is there something wrong with this thread? This could mean suspended or no longer exists or etc. It is a problem because it is implementation dependent. |
| epicsThreadSleep | Sleep for the specified period of time, i.e. sleep without using the cpu. If delay is >0 then the thread will sleep at least until the next clock tick. The exact time is determined by the underlying architecture. If delay is <= 0 then a delay of 0 is requested of the underlying architecture. What happens is architecture dependent but often it allows other threads of the same priority to run. |
| epicsThreadSleepQuantum | This function returns the minimum slumber interval obtainable with epicsThreadSleep() in seconds. On most OS there is a system scheduler interrupt interval which determines the value of this parameter. Knowledge of this parameter is used by the various components of EPICS to improve scheduling of software tasks intime when the reduction of average time scheduling errors is important.If this parameter is unknown or is unpredictable for a particular OS then it is safe to return zero. |
| epicsThreadGetIdSelf | Get the threadId of the calling thread. |
| epicsThreadGetId | Get the threadId of the specified thread. A return of 0 means that no thread was found with the specified name. |
| epicsThreadGetNameSelf | Get the name of the calling thread. |
| epicsThreadGetName | Get the name of the specified thread. The value is copied to a caller specified buffer so that if the thread terminates the caller is not left with a pointer to something that may no longer exist. |
| epicsThreadIsOkToBlock | Is it OK for a thread to block? This can be called by support code that does not know if it is called in a thread that should not block. For example the errlog system calls this to decide when messages should be displayed on the console. |
| epicsThreadSetOkToBlock | When a thread is started the default is that it is not allowed to block. This method can be called to change the state. For example iocsh calls this to specify that it is OK to block. |
| epicsThreadShowAll | Display info about all threads. |
| epicsThreadShow | Display info about the specified thread. |
| epicsThreadPrivateCreate | Thread private variables are intended for use by legacy libraries written for a single threaded environment and which uses a global variable to store private data. The only code in base that currently needs this facility is channel access. A library that needs a private variable should make exactly one call to epicsThreadPrivateCreate. Each thread should call epicsThreadPrivateSet when the thread is created. Each library routine can call epicsThreadPrivateGet each time it is called. |
| epicsThreadPrivateDelete | Delete a thread private variable. |
| epicsThreadPrivateSet | Set the value for a thread private variable. |
| epicsThreadPrivateGet | Get the value of a thread private variable, the value is the value set by the call to epicsThreadPrivateSet that was made by the same thread. If called before epicsThreadPrivateSet it returns 0. |
epicsThread is meant as a somewhat minimal interface for multithreaded applications. It can be implemented on a wide variety of systems with the restriction that the system MUST support a multithreaded environment. A POSIX pthreads version is provided.
The interface provides the following thread facilities, with restrictions as noted:
class epicsThreadRunable {
public:
virtual void run() = 0;
virtual void stop();
virtual void show(unsigned int level) const;
class epicsShareClass epicsThread {
public:
epicsThread (epicsThreadRunable &,const char *name, unsigned int stackSize,
unsigned int priority=epicsThreadPriorityLow);
virtual ~epicsThread ();
void start();
void exitWait ();
bool exitWait (const double delay );
void exitWaitRelease (); // noop if not called by managed thread
static void exit ();
void resume ();
void getName (char *name, size_t size) const;
epicsThreadId getId () const;
unsigned int getPriority () const;
void setPriority (unsigned int);
bool priorityIsEqual (const epicsThread &otherThread) const;
bool isSuspended () const;
bool isCurrentThread () const;
bool operator == (const epicsThread &rhs) const;
/* these operate on the current thread */
static void suspendSelf ();
static void sleep (double seconds);
static epicsThread & getSelf ();
static const char * getNameSelf ();
static bool isOkToBlock ();
static void setOkToBlock(bool isOkToBlock) ;
private:
template <class T>
class epicsThreadPrivate {
public:
epicsThreadPrivate ();
~epicsThreadPrivate ();
T *get () const;
void set (T *);
class unableToCreateThreadPrivate {}; // exception
private:
The C++ interface is just a wrapper around the C interface. Two differences are the method start and the class
epicsThreadRunable.
The method start must be called only after the epicsThead object is constructed. It in turn calls the run method of
the epicsThreadRunable object.
Code using the C++ interface code must provide a class that derives from epicsThreadRunable. One way to
accomplish this is as follows:
class myThread: public epicsThreadRunable {
public:
myThread(int arg,const char *name);
virtual ~myThread();
virtual void run();
epicsThread thread;
myThread::myThread(int arg,const char *name) :
thread(*this,name,epicsThreadGetStackSize(epicsThreadStackSmall),50)
thread.start();
myThread::~myThread() {}
void myThread::run()
epicsTime.h contains C++ and C descriptions for time.
/* epics time stamp for C interface*/
typedef struct epicsTimeStamp {
epicsUInt32 secPastEpoch; /* seconds since 0000 Jan 1, 1990 */
epicsUInt32 nsec; /* nanoseconds within second */
} epicsTimeStamp;
/*TS_STAMP is deprecated */
#define TS_STAMP epicsTimeStamp
struct timespec; /* POSIX real time */
struct timeval; /* BSD */
struct l_fp; /* NTP timestamp */
// extend ANSI C RTL "struct tm" to include nano seconds within a second
// and a struct tm that is adjusted for the local timezone
struct local_tm_nano_sec {
struct tm ansi_tm; /* ANSI C time details */
unsigned long nSec; /* nano seconds extension */
// extend ANSI C RTL "struct tm" to includes nano seconds within a second
// and a struct tm that is adjusted for GMT (UTC)
struct gm_tm_nano_sec {
// wrapping this in a struct allows conversion to and
// from ANSI time_t but does not allow unexpected
// conversions to occur
struct time_t_wrapper {
time_t ts;
The above structures are for the various time formats.
epicsTimeStamp - This is the structure used by the C interface for epics time stamps. The C++ interface stores
this information in private members. The two elements of the class are:
secPastEpoch - The number of seconds since January 1, 1990 (the epics epoch).
nsec - nanoseconds within a second
NOTE: TS_STAMP is defined for compatibility with existing code.
timespec - This is defined by POSIX Real Time. It requires two mandatory fields:
time_t tv_sec - Number of seconds since 1970 (The POSIX epoch)
long tv_nsec - nanoseconds within a second
timeval - BSD and SRV5 Unix timestamp. It has two fields:
time_t tv_nsec - nanoseconds within a second
struct l_fp - Network Time Protocol timestamp. The fields are:
lui - Number of seconds since 1900 (The NTP epoch)
luf - Fraction of a second. For example 0x800000000 represents 1/2 second.
local_tm_nano_sec and gm_tm_nano_sec - Defined by epics. These just add a nanosecond field to struct tm.
time_t_wrapper - This is for converting to/from the ANSI C time_t. Since time_t is usually an
elementary type providing a conversion operator from time_t to/from epicsTime could cause undesirable
implicit conversions. Providing a conversion operator to/from a time_t_wrapper prevents implicit
conversions.
NOTE on conversion. The epics implementation will properly convert between the various formats from the beginning of the EPICS epoch until at least 2038. Unless the underlying architecture support has defective POSIX, BSD/SRV5, or standard C time support the epics implementation should be valid until 2106.
class epicsTime;
class epicsTimeEvent {
public:
epicsTimeEvent (const int &number);
operator int () const;
private:
int eventNumber;
class epicsTime {
public:
// exceptions
class unableToFetchCurrentTime {};
class formatProblemWithStructTM {};
epicsTime ();
epicsTime (const epicsTime &t);
static epicsTime getEvent (const epicsTimeEvent &event);
static epicsTime getCurrent ();
// convert to and from EPICS epicsTimeStamp format
operator epicsTimeStamp () const;
epicsTime (const epicsTimeStamp &ts);
epicsTime operator = (const epicsTimeStamp &rhs);
// convert to and from ANSI time_t
operator time_t_wrapper () const;
epicsTime (const time_t_wrapper &tv);
epicsTime operator = (const time_t_wrapper &rhs);
// convert to and from ANSI Cs "struct tm" (with nano seconds)
// adjusted for the local time zone
operator local_tm_nano_sec () const;
epicsTime (const local_tm_nano_sec &ts);
epicsTime operator = (const local_tm_nano_sec &rhs);
// convert to ANSI Cs "struct tm" (with nano seconds)
// adjusted for GM time (UTC)
operator gm_tm_nano_sec () const;
// convert to and from POSIX RT's "struct timespec"
operator struct timespec () const;
epicsTime (const struct timespec &ts);
epicsTime operator = (const struct timespec &rhs);
// convert to and from BSD's "struct timeval"
operator struct timeval () const;
epicsTime (const struct timeval &ts);
epicsTime operator = (const struct timeval &rhs);
// convert to and from NTP timestamp format
operator l_fp () const;
epicsTime (const l_fp &);
epicsTime operator = (const l_fp &rhs);
// convert to and from WIN32s FILETIME (implemented only on WIN32)
operator struct _FILETIME () const;
epicsTime ( const struct _FILETIME & );
epicsTime & operator = ( const struct _FILETIME & );
// arithmetic operators
double operator- (const epicsTime &rhs) const; // returns seconds
epicsTime operator+ (const double &rhs) const; // add rhs seconds
epicsTime operator- (const double &rhs) const; // subtract rhs seconds
epicsTime operator+= (const double &rhs); // add rhs seconds
epicsTime operator-= (const double &rhs); // subtract rhs seconds
// comparison operators
bool operator == (const epicsTime &rhs) const;
bool operator != (const epicsTime &rhs) const;
bool operator <= (const epicsTime &rhs) const;
bool operator < (const epicsTime &rhs) const;
bool operator >= (const epicsTime &rhs) const;
bool operator > (const epicsTime &rhs) const;
// convert current state to user-specified string
size_t strftime (char *pBuff, size_t bufLength, const char *pFormat) const;
// dump current state to standard out
void show (unsigned interestLevel) const;
private:
class epicsShareClass epicsTimeEvent
public:
private:
int eventNumber;
| Method | Meaning |
| Convert to/from integer | Does not currently check that the range of the integer is valid, although it might one day. |
| Method | Meaning |
| epicsTime() | The default constructor sets the time to the beginning of the epics epoch. |
| epicsTime(const epicsTime& t); | The default constructor sets the time to the beginning of the epics epoch. |
| static getEvent | Returns an epicsTime indicating when the associated event last occurred. See the description of the C routine epicsTimeGetEvent below for details. |
| static getCurrent | Returns an epicsTime containing the current time. An example is: epicsTime time = epicsTime::getCurrent(); |
| convert to/fromepicsTimeStamp | Three methods are provided for epicsTimeStamp. A copy constructor, an assignment operator, and a conversion to epicsTimeStamp. Assume the following definitions: epicsTime time; epicsTimeStamp ts;An example of the copy constructor is: epicsTime time1(ts);An example of the assignment operator is: time = ts;An example of the epicsTimeStamp operator is: ts = time; |
| Convert to/fromANSI time_t | Three methods are provided for ANSI time_t. A copy constructor, an assignment operator, and a conversion to time_t_wrapper. The structure time_t_wrapper must be used instead of time_t because undesired conversions could occur: Assume the following definitions: time_t tt; time_t_wrapper ttw; epicsTime time;An example of the copy constructor is: ttw.tt = tt; epicsTime time1(ttw);An example of the assignment operator is: time = ttw;An example of the time_t_wrapper operator is: ttw = time; tt = ttw.tt; |
| convert to and fromtm_nano_sec | Three methods are provided for tm_nano_sec A copy constructor, an assignment operator, and a conversion to tm_nano_sec. Assume the following definitions: local_tm_nano_sec ttn; epicsTime time;An example of the copy constructor is: epicsTime time1(ttn);An example of the assignment operator is: time = ttn;An example of the tm_nano_sec operator is: ttn = time; |
| convert to and fromPOSIX RT's ``struct timespec" | Three methods are provided for struct timespec. A copy constructor, an assignment operator, and a conversion to struct timespec. Assume the following definitions: struct timespec tts; epicsTime time;An example of the copy constructor is: epicsTime time1(tts);An example of the assignment operator is: time = tts;An example of the struct timespec operator is: tts = time; |
| convert to and from BSD's ``struct timeval" | Three methods are provided for struct timeval. A copy constructor, an assignment operator, and a conversion to struct timeval. Assume the following definitions: struct timeval ttv; epicsTime time;An example of the copy constructor is: epicsTime time1(ttv);An example of the assignment operator is: time = ttv;An example of the struct timeval operator is: ttv = time; |
| convert to and from NTP timestamp format | Three methods are provided for ntpTimeStamp. A copy constructor, an assignment operator, and a conversion to ntpTimeStamp. Assume the following definitions: l_fp ntp; epicsTime time;An example of the copy constructor is: epicsTime time1(ntp);An example of the assignment operator is: time = ntp;An example of the ntpTimeStamp operator is: ntp = time; |
| arithmetic operators- ++=-= | The arithmetic operators allow the difference of two epicsTimes, with the result in seconds. It also allows -, +, +=, and -= where the left hand argument is an epicsTime and the right hand argument is a double. Examples are: epicsTime time, time1, time2; double t1,t2,t3; ... t1 = time2 - time1; time = time1 + 4.5; time = time2 - t3; time2 += 6.0; |
| Comparison operators==, |=, <=, <, >=, > | Two epics times can be compared: epicsTime time1, time2; ... if(time1<=time2) { ... |
| strftime | This is a facility similar to the ANSI C library routine strftime. See K&R for details about strftime. The epicsTime method also provides support for the printing the nanoseconds portion of the time. It looks in the format string for the sequence ``%0nf" where n is the desired precision. It uses this format to convert the nanoseconds value to the requested precision. For example: epicsTime time = epicsTime::getCurrent(); char buf[30]; time.strftime(buf,30,"%Y/%m/%d %H:%M:%S.%06f"); printf("%s\n",buf);Will print the time in the format: 2001/01/26 20:50:29.813505 |
| show | Shows the date/time. |
/* All epicsTime routines return (-1,0) for (failure,success) */
#define epicsTimeOK 0
#define epicsTimeERROR (-1)
/*Some special values for eventNumber*/
#define epicsTimeEventCurrentTime 0
#define epicsTimeEventBestTime -1
#define epicsTimeEventDeviceTime -2
/* These are implemented in the "generalTime" framework */
int epicsTimeGetCurrent (epicsTimeStamp *pDest);
int epicsTimeGetEvent (epicsTimeStamp *pDest, int eventNumber);
/* These are callable from an Interrupt Service Routine */
epicsShareFunc int epicsTimeGetCurrentInt(epicsTimeStamp *pDest);
epicsShareFunc int epicsTimeGetEventInt(epicsTimeStamp *pDest, int eventNumber);
/* convert to and from ANSI C's "time_t" */
int epicsTimeToTime_t (time_t *pDest, const epicsTimeStamp *pSrc);
int epicsTimeFromTime_t (epicsTimeStamp *pDest, time_t src);
/*convert to and from ANSI C's "struct tm" with nano seconds */
int epicsTimeToTM (struct tm *pDest, unsigned long *pNSecDest,
int epicsTimeToGMTM (struct tm *pDest, unsigned long *pNSecDest,
int epicsTimeFromTM (epicsTimeStamp *pDest, const struct tm *pSrc,
unsigned long nSecSrc);
/* convert to and from POSIX RT's "struct timespec" */
int epicsTimeToTimespec (struct timespec *pDest, const epicsTimeStamp *pSrc);
int epicsTimeFromTimespec (epicsTimeStamp *pDest, const struct timespec *pSrc);
/* convert to and from BSD's "struct timeval" */
int epicsTimeToTimeval (struct timeval *pDest, const epicsTimeStamp *pSrc);
int epicsTimeFromTimeval (epicsTimeStamp *pDest, const struct timeval *pSrc);
/*arithmetic operations */
double epicsTimeDiffInSeconds (
const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight);
void epicsTimeAddSeconds (
epicsTimeStamp *pDest, double secondsToAdd); /* adds seconds to *pDest */
/*comparison operations: returns (0,1) if (false,true) */
int epicsTimeEqual(const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight);
int epicsTimeNotEqual(const epicsTimeStamp *pLeft,const epicsTimeStamp *pRight);
int epicsTimeLessThan(const epicsTimeStamp *pLeft,const epicsTimeStamp *pRight);
int epicsTimeLessThanEqual(
int epicsTimeGreaterThan (
int epicsTimeGreaterThanEqual (
/*convert to ASCII string */
size_t epicsTimeToStrftime (
char *pBuff, size_t bufLength, const char *pFormat, const epicsTimeStamp
*pTS);
/* dump current state to standard out */
void epicsTimeShow (const epicsTimeStamp *, unsigned interestLevel);
/* OS dependent reentrant versions of the ANSI C interface because */
/* vxWorks gmtime_r interface does not match POSIX standards */
int epicsTime_localtime ( const time_t *clock, struct tm *result );
int epicsTime_gmtime ( const time_t *clock, struct tm *result );
The C interface provides most of the features as the C++ interface. The features of the C++ operators are provided as functions.
Note that the epicsTimeGetCurrent and epicsTimeGetEvent routines are now implemented in epicsGeneralTime.c
osiPoolStatus.h contains the following description:
int osiSufficentSpaceInPool(void);
| Method | Meaning |
| osiSufficentSpaceInPool | Return (true,false) if there is sufficient free memory. |
This determines if enough free memory exists to continue.
A vxWorks version returns (true,false) if memFindMax returns (>100000, <=100000) bytes.
The default version always returns true.
osiProcess.h contains the following:
typedef enum osiGetUserNameReturn {
osiGetUserNameFail,
osiGetUserNameSuccess
}osiGetUserNameReturn;
osiGetUserNameReturn osiGetUserName (char *pBuf, unsigned bufSize);
* Spawn detached process with named executable, but return
* osiSpawnDetachedProcessNoSupport if the local OS does not
* support heavy weight processes.
typedef enum osiSpawnDetachedProcessReturn {
osiSpawnDetachedProcessFail,
osiSpawnDetachedProcessSuccess,
}osiSpawnDetachedProcessReturn;
osiSpawnDetachedProcessReturn osiSpawnDetachedProcess(
const char *pProcessName, const char *pBaseExecutableName);
Not documented.
osiSigPipeIgnore.h contains the following:
void installSigPipeIgnore (void);
Not documented.
See the header file in <base>/src/libCom/osi.
NOTE: EPICS Base only provides vxWorks and RTEMS back-end implementations of these routines. Versions of the back-end routines for other operating systems can be added in a support or IOC application.
devLib.h provides definitions for a library of routines useful for device and driver modules, which are primarily
indended for accessing VME devices. If all VME drivers register with these routines then addressing conflicts caused by
multiple device/drivers trying to use the same VME addresses will be detected.
long devReadProbe(
unsigned wordSize,
volatile const void *ptr,
void *pValueRead);
Performs a bus-error-safe atomic read operation width wordSize bytes from the ptr location, placing the value read (if
successful) at pValueRead. The routine returns a failure status (non-zero) if a bus error occurred during the read cycle.
long devWriteProbe(
unsigned wordSize,
volatile void *ptr,
const void *pValueWritten);
Performs a bus-error-safe atomic write operation width wordSize which copies the value from pValueWritten to the
ptr location. The routine returns a failure status (non-zero) if a bus error occurred during the write cycle.
long devNoResponseProbe(
epicsAddressType addrType,
size_t base,
size_t size);
This routine performs a series of read probes for all word sizes from char to long at every naturally aligned location in the
range [base, base+size) for the given bus address type. It returns an error if any location responds or if any such
location cannot be mapped.
typedef enum {
atVMEA16, atVMEA24, atVMEA32,
atISA,
atLast /* atLast is the last enum in this list */
} epicsAddressType;
char *epicsAddressTypeName[] = {
"VME A16", "VME A24", "VME A32",
"ISA"
long devRegisterAddress(
const char *pOwnerName,
size_t logicalBaseAddress,
size_t size, /* bytes */
volatile void **pLocalAddress);
This routine is called to register a VME address. The routine keeps a list of all VME address ranges requested and returns
an error message if an attempt is made to register any addresses that overlap a range that is already being used.
*pLocalAddress is set equal to the address as seen by the caller.
long devAddressMap(void)
This routine displays the table of registered VME address ranges, including the owner of each registered address.
long devUnregisterAddress(
const char *pOwnerName);
This routine releases address ranges previously registered by a call to devRegisterAddress or devAllocAddress.
long devAllocAddress(
size_t size,
unsigned alignment, /*number of low zero bits needed in addr*/
This routine is called to request the library to allocate an address block of a particular address type. This is useful for devices that appear in more than one address space and can program the base address of one window using registers found in another window.
long devConnectInterruptVME(
unsigned vectorNumber,
void (*pFunction)(void *),
void *parameter);
Connect ISR pFunction up to the VME interrupt vectorNumber.
long devDisconnectInterruptVME(
void (*pFunction)(void *));
Disconnects an ISR from its VME interrupt vector. The parameter pFunction should be set to the C function pointer
that was connected. It is used as a key to prevent a driver from inadvertently removing an interrupt handler that it didn't
install.
int devInterruptInUseVME(
unsigned vectorNumber);
Determines if a VME interrupt vector is in use, returning a boolean value.
long devEnableInterruptLevelVME(
unsigned level);
Enable the given VME interrupt level onto the CPU.
long devDisableInterruptLevelVME(
unsigned level);
Disable VME interrupt level. This routine should generally never be used, since it is impossible for a driver to know whether any other active drivers are still making use of a particular interrupt level.
#define devCreateMask(NBITS)((1<<(NBITS))-1)
#define devDigToNml(DIGITAL,NBITS) \
(((double)(DIGITAL))/devCreateMask(NBITS))
#define devNmlToDig(NORMAL,NBITS) \
(((long)(NORMAL)) * devCreateMask(NBITS))
typedef enum {intCPU, intVME, intVXI} epicsInterruptType;
The routines that use this typedef have all been deprecated, and currently only exist for backwards compatibility purposes. The typedef will be removed in a future release, along with those routines.
long devConnectInterrupt(
epicsInterruptType intType,
void (*pFunction)(),
void *parameter);
This routine has been deprecated, and currently only exists for backwards compatibility purposes. Uses of this routine
should be converted to call devConnectInterruptVME or related routines instead. This routine will be removed in a
future release.
long devDisconnectInterrupt(
should be converted to call devDisconnectInterruptVME or related routines instead. This routine will be removed
in a future release.
long devEnableInterruptLevel(
unsigned level);
should be converted to call devEnableInterruptLevelVME or related routines instead. This routine will be removed
long devDisableInterruptLevel(
unsigned level);
should be converted to call devDisableInterruptLevelVME or related routines instead. This routine will be
removed in a future release.
The routines described in this section are included in a application by the Makfile command:
<appl>_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
This routine shows the vxWorks interrupt vector table, but only works properly on 68K family CPUs.
This traps all calls to logMsg and sends them to errlogPrintf.
This provides the routines symFindByNameEPICS and symFindByNameAndTypeEPICS.
It is only provided for modules that have not been converted to use epicsFindSymbol.
These routines are deprecated.
This is only provided for device/driver support that have not been converted to use OSI features of base.
This header is deprecated.
Instead of using this, drivers should register a configuration command to obtain
the information originally provided by module_types.h
This is only provided for device/driver support that have not been converted to use OSI features of base. This header is deprecated.
This routine causes epicsDynLink, logMsgToErrlog and veclist to be loaded.
