Detector Quick Select
Energy Dispersive Detectors:
There are six units which are listed in the data base as 5, 7, 10 mm (the active areas, in mm**2). The 7 mm detectors are later models and have high (3000) peak/background ratios. Two of the Ketek's are "Low Energy" models meaning the window is a polymer, not Be.
Radiant Technology Vortex, Vortex-EX
There are two Vortex and three Vortex-EX silicon drift diode detectors. The "-EX" means "extended snout".
Canberra Germanium Detectors
There are three units: 4" snout, 12" snout, and 13 element detector. LN2 filled.
Amptek CdZnTe
There is one unit.
There is one of each unit.
Current Detectors:
Oxford Instruments
We have 4 Oxford Instruments Ion chambers
Area Detectors:
MAR 165 CCD Camera
We have 2 MAR165's, 165 mm diameter phosphor-fiberoptic taper - CCD based detector.
MAR 345 Image Plate
We have 2 MAR345's, 345 mm diameter image plates.
General Electric
We have a General Electric Medical amorphous silicon large area detector.
Photometrics Roper Cool Snap
We have 2 Princeton Instruments/Roper Cool-SnapHQ detectors. Typically used with a Zeiss tube lens, with microscope objectives which image the YAG scintillator onto the CCD.
Electronics:
(Incomplete listing...)
We have Keyboard, Mouse, Monitor extender systems. (typically used with CoolSnap).
