Guide to Installing SDDS and OAG Simulation Software on Windows Computers
M. Borland, R. Soliday
Step 1 - Download the required files
A. Download OAG software:
SDDS Toolkit.exe REQUIRED
Microsoft Visual C++ 2008 SP1 Redistributable Package REQUIRED if not already installed
SDDS Epics Toolkit.exe optional (control system programs)
Elegant.exe optional (accelerator simulation)
Spiffe.exe optional (rf gun simulation)
Shower.exe optional (electron-gamma shower simulation)
Java SDDS Software.exe optional (editor for SDDS files)
B. Download OAG software manuals. This is optional, but provides a handy
local copy of the manuals, particularly useful for laptop users who
don't have an internet connection all the time.
OAGManuals.exe
An easy introduction to SDDS is available in "Getting Started with SDDS,"
available as
HTML,
PDF,
or
postscript.
You can also download sample
data
so you can work
along with the examples in this document.
C. Download example simulation files:
These are available from the manuals page,
http://www.aps.anl.gov/Accelerator_Systems_Division/Operations_Analysis/oagSoftware.shtml
Look for the links in the sections for each of the programs
that you are interested in.
Save these files to disk. We'll unpack them below.
D. Download the CYGWIN UNIX shell, from
http://sources.redhat.com/cygwin/mirrors.html
As of this writing, the self-installing executable is setup.exe.
Download and execute the setup.exe. From the dialog box that appears,
select "Install from Internet", and follow directions.
E. If you are planning on using any Java software download
the Java Runtime Environment, from
http://java.sun.com/j2se/1.5.0/download.jsp
Step 2
Install the downloaded software. This will require rebooting your
computer numerous times.
Step 3
Set up CYGWIN. Open a CYGWIN shell (Start > Programs > Cygnus Solutions > Cygwin Bash Shell) and type the following:
cd /c
mkdir bin
mkdir tmp
cd bin
ln -s C:/cygwin/bin/sh.exe sh.exe
ln -s C:/cygwin/bin/tclsh.exe tclsh.exe
Using the TAB key for automatic filename completion can make typing
in long paths and filenames quicker.
Next, create a .bashrc file in the toplevel on your C drive, with the
following contents:
PATH="$PATH:.:/cygdrive/c/bin"
These steps will make it easier to set up and run your own sh and
tclsh scripts. The .bashrc file can also be used for other
customizations of the CYGWIN shell.
Step 4
Unpack the example files for the programs you are interested in.
To do this, open a CYGWIN shell. For any files that have the .gz
extension, use "gzip -d [filename]" to uncompress the file. Then, use
the tar utility to unpack the library, e.g., "tar xvf
elegantExamples.tar".
Once you've unpacked the files, cd to the directory and start looking
around. There are usually "README" or "Notebook" files that guide you
through the examples. Typically, you'll find one or more scripts that
you can run to execute the example.
