Argonne National Laboratory
Accelerator Operations & Physics
Advance Photon Source
A U.S. Department of Energy, Office of Science,
Office of Basic Energy Sciences national synchrotron x-ray research facility
Argonne Home > Advanced Photon Source > Accelerator Systems Division > Accelerator Operations & Physics
Guide to Installing SDDS support for Matlab
R. Soliday
Step 1 Linux
Download or build the SDDS Java Binary (JAR) file.
Step 1 Windows
Download the Java SDDS Binaries or build the the SDDS Java Binary (JAR) file.
Step 2 Linux
Edit /usr/local/matlab/toolbox/local/classpath.txt (your location may be different) and add a link to SDDS.jar.
Step 2 Windows
Edit C:\MATLAB6p1\toolbox\local\classpath.txt (your location may be different) and add a link to c:/Program Files/APS/Java SDDS/SDDS.jar
Step 3
If your Matlab version is older than version 13 you will have to install the Java Runtime Environment version 1.3.1. The newer versions will not work with Matlab and the version that comes with Matlab is too old to work with the Java SDDS library. Once installed you will have to set the environment variable MATLAB_JAVA to the directory of the JRE.
Step 4
Download and unpack the SDDS Matlab M-Files. These files can be used by Matlab if they are in the current working directory or if they are added to Matlab's path.
Step 5
You can now load sdds files into a Matlab structure. The structure looks like:
sdds.filename
sdds.ascii
sdds.pages
sdds.parameter_names
sdds.array_names
sdds.column_names
sdds.description.contents
                .text
sdds.parameter.[parameter name].type
                               .units
                               .symbol
                               .format_string
                               .description
                               .data
sdds.column.[column name].type
                         .units
                         .symbol
                         .format_string
                         .description
                         .page[number]
sdds.array.[array name].dimensions
                       .type
                       .units
                       .symbol
                       .format_string
                       .group_name
                       .description
                       .size_page[number]
                       .page[number]
The commands for loading and saving SDDS files from Matlab are:
sdds = sddsload('inputFile.sdds') % Load inputFile.sdds
sddssave(sdds)                    % Save to sdds.filename
sddssave(sdds, 'outputFile.sdds') % Save to outputFile.sdds
Note: Not all fields are required to save an SDDS file.
Answers to common questions
The values for columns are returned asjava.lang.struct objects.
How do I convert these into MATLAB vectors?
Using the SDDSUtil.castArrayAsDouble command. Here is an example:
import SDDS.java.SDDS.*
sdds = sddsload('/tmp/junk')
sdds.column.[column name].page1 =
  SDDSUtil.castArrayAsDouble(sdds.column.[column name].page1,
                             SDDSUtil.identifyType(sdds.column.[column name].type))
I am getting the error message java.lang.OutOfMemoryError what do I do?
When Matlab starts the java interpreter it starts it with a maximum
Java memory heap size which is often too small. On Solaris all I have
to do is start Matlab from a directory that contains a file called
java.opts. This file has one line:
-Xmx268435456
This tells matlab to start the java interpreter with 256 MBs as the
maximum Java memory heap size.
I think on Windows this file would go in the directory where the
Matlab binary is.
If you have problems please email me at soliday@aps.anl.gov
